Hole For Recessed Box In Kitchen Wall
Wind Gatherer
Has thanked: 46 times
Post by Wind Gatherer »
How do I make an opening in one of the tiles making up the next row, for the metal light box and cover plate? See photo
Cheers.
Pic attached. Mod 2.
darrenba
Has thanked: 104 times
Been thanked: 490 times
Re: Hole For Recessed Box In Kitchen Wall
Post by darrenba »
Have you got a small angle grinder?
Wind Gatherer
darrenba wrote:Have you got a small angle grinder?
Yes I have.
DIY_Johnny
Mr. Grumpy
Has thanked: 25 times
Been thanked: 109 times
Post by DIY_Johnny »
i used wet tile cutter to cut out square of tile, as didn't have angle grinder. Worked out fine
Wind Gatherer
DIY_Johnny wrote:i used wet tile cutter to cut out square of tile, as didn't have angle grinder. Worked out fine
Hi thanks, I bought an Xtreme 600W wet tile cutter from Argos. Can you go into more detail how you mark it out, set out the tile for cutting?
Thanks.
darrenba
Post by darrenba »
Easier and safer with a tile blade like this in an angle grinder, to do it with a wet cutter you'll need to remove the safety guard
http://www.screwfix.com/p/erbauer-turbo ... 23mm/64706
DIY_Johnny
Mr. Grumpy
Thanks.
Just to answer your question, this is what I did:
1) Mark a square/rectangle the size of the back box or plasterboard box on the face of the tile.
2) Drill four pilot (3mm I think) holes in each corner from the front face.
3) Take the guard off the tile cutter, place the tile face down on the spinning blade. The 4 holes are simply used so that you can see that the blade is lined up with a line of the rectangle. Press the tile slowly into the blade so it starts to cut away.
4) As you see the blade coming through the tile you should remember that the cut face underneath will be longer than what you see above (due to the circular nature of the blade) so good to keep checking. If you cut all the way through to the two holes you will have cut past the holes on the decorative face.
5) Turn the tile upside down and cut from the underside to finish off.
6) You only need to cut 3 lines as the 4th will snap off if you have used a tile blade to score the 4th edge.
Some notes
  • I am just a DIYer and this is just my made up idea on the day as I didn't have a angle grinder. Darrens way seems more straight forward.
  • I tried just marking the tile and just placing the tile face down with any holes but the water soon removed the marking and I was getting dirty water splashed in my face
  • As the tile guard is off, water will fling everywhere so you might get wet, best to do it outside and wear goggles
I would just use the angle grinder, less messing about
Tile 2.jpg (547.01 KiB) Viewed 2007 times
Tile 1.jpg (411.37 KiB) Viewed 2007 times
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
darrenba wrote:Easier and safer with a tile blade like this in an angle grinder, to do it with a wet cutter you'll need to remove the safety guard
:withstupid:
DIY_Johnny
Mr. Grumpy
You guys make life too easy, wheres the fun? :mrgreen:
Wind Gatherer
Thanks.
Some notes
OK thanks very much for taking the trouble to post all the details.
Wind Gatherer
OK thanks, will see if can get it at a better price on Ebay. Yes, don't want to take the blade guard off, and take my fingers off, same with taking the guard off my 3hp tablesaw.
Cheers.
