Repairing advice needed
- Has thanked: 2 times
We have just removed the tiles from the bathroom and are not 100% sure if we need to repair the walls.
Brick wall - outside wall
Plasterboard - inside wall
Also we are not sure how to repair the window ledge
- Has thanked: 108 times
- Been thanked: 1038 times
- Has thanked: 19 times
- Been thanked: 21 times
- Megaross
- Has thanked: 28 times
- Been thanked: 110 times
Re: Repairing advice needed
Oh yeah that needs at least filling and by the time you've pissed around filling you may as well have skimmed - you need a flat, sound surface to tile on.
1. Because the tiles won't grip to unsound surfaces
2. Because the files won't be flat if the surface is bumpy and knackered
9/10 retiling means new plasterboard and a full skim for any areas where the tiles are removed. Thing to remember though is the skim needn't be perfectly smooth for tiles - it's actually better for it to have a bit of roughness to it as long as it's nice and flat and well bonded.
Unibond it a couple of times, skim over with multifinish and then when it's dry give it a coat of SBR before tiling.
Note: I notice you say large tiles - if the tiles are over 20kg per m2 you won't be able to tile on to plaster skim, if they're over 30kg per m2 you won't be able to tile on to tanked plasterboard. You'll need to line the surfaces to be tiled with hardibacker or something like that.
- Has thanked: 67 times
- Been thanked: 106 times
Until it all falls off!corematrix wrote:Looking good, now didn't have to do much repair just some filler.
You didn't say if you took any notice of Megaross's advice. Good luck.
Ended up using a professional tiler with 15 years of experiences so hopefully he knows what he's doing.
