Can you identify what make of battery this is?
This forum is for reviews of Budget power tools such as B&Q / Wickes own brand, Direct power / Titan / challenge / Performance power / Erbauer / Skill/ Bosch Green / Black & Decker
Gurkin
Has thanked: 46 times
Been thanked: 2 times
Post by Gurkin »
Hi All,
can anyone that's cleverer than me, please help identify the manufacturer of this battery or one that's compatible, please.
Thanks in advance,
G
UHM 3.JPG (224.06 KiB) Viewed 10634 times
UHM 2.JPG (232.27 KiB) Viewed 10634 times
UHM 1.JPG (230.49 KiB) Viewed 10634 times
Razor
Has thanked: 483 times
Been thanked: 1251 times
Re: Can you identify what make of battery this is?
Post by Razor »
Is that an old FERM kit??
Razor
Post by Razor »
NB This auction is for a 12V one but it looks the same to me :wink:
http://www.ebay.co.uk/itm/Ferm-FDC-1200 ... 58b5b37cf8
Gurkin
Post by Gurkin »
The make on the box is "Strategy", it was bought by my Dad from QVC several years ago. Was only used half dozen times. Yesterday he charged and briefly tested, but is almost dead today.
Thanks for the replies.
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 566 times
Post by moderator2 »
Moved from carpentry.
Gurkin
Post by Gurkin »
Thanks for the lead on Ferm. Indeed, the housing on this one looks very similar.
Any ideas where I could get and compatible 18v from?
Has thanked: 1414 times
Been thanked: 4015 times
Looks like a fairly generic own brand tool as made for argos/b&q/homebase/maplins et al...
If I remember correctly the company that supplied them were based in Birmingham ?? they went by the name of Nu-tool..
Has thanked: 807 times
Been thanked: 3498 times
The cost of a battery if you could source one would probably be around £40 plus each. I have a Dewalt drill body where it is totally uneconomic to buy the batteries. You would do better to go for the Hitachi drill with two li ion batteries for £99 at Screwfix.
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
It only take a very small change in battery shape (change in notch position, length, width etc) to stop the battery dropping in the charger. Manufacturers commonly implement this trick to keep their batteries 'propriatory' (i.e. stop you using others and charge you more for proper replacements).
As already mentioned it would be far wiser to purchase a known model with spare batteries included.
fin
Has thanked: 32 times
Been thanked: 805 times
Post by fin »
my local screw fix has a bosch 18v cordless. 1 battery for £75 quid ish. even if its a lower end pro bosch itll still be better than one of the older unbranded kind of drills.
maybe worth checking screw fix out see what they have in stock
Has thanked: 734 times
Been thanked: 2335 times
i once had three batteries [argos/challenge 18v lidl parkside drill lidl circsaw] all 3 batteries would fit the drill but all would only charge in there own charger
as said new kit will be more cost efficient
Gurkin
Post by Gurkin »
Sorry, for the late reply. I had to go to work.
Anyway, thanks for the replies. I've passed on your recommendations. But, he hates putting things into landfill. As this tool has hardly had any use, he's adamant that he'd like to source a battery, even though it may not be economically viable and technology has moved on since then.
Just a a matter of interest, do the cells just die on the old Ni-Cd batteries? I thought that only occurred after so many charging cycles.
You could try this firm http://www.batteryfix.co.uk/
batteries will fail with age used or not
imho a battery cycled once every 2 or 3 months will give you greater life than a dormant battery
by cycling i mean run till 95-98% flat then charged
now others will disagree but it works for me this is nicads only
with nmh or li-ions i tend to charge when they are around half charged when inactive or little use
of course in use you charge when they need
Return to “budget power tools ”
