Attic Robes
- Has thanked: 1 time
- Been thanked: 69 times
Attic Robes
Got these fitted over the last couple of days. had a bit of a problem with the robes as the ceiling swept up at one point more than I had allowed on the filler strip. I will have to make a new filler strip and return to fit it along with the cornice. I will have to then fit the handles as the wrong ones were sent.
Anyway here are the photos so far. I managed to get the drawer units fitted with a bit more luck but even this gave me a headache as one of the drawer runners broke as soon as the box was fitted! As soon as the box was slid in one of the small plastic tabs broke off for the soft close! It still works well but without soft close now. I shall have to order another set or maybe even complain a bit and see what happens. Here are the photos of these in place and these were the correct handles....luckily. Ignore the screw holes in the architrave as they might be coming off again to accommodate a slide out shoe rack next to the drawers. (More work for me)
Never enough hours in the day!
http://www.alanwilley.co.uk/
Re: Attic Robes
That is a good way of utilising some awkwardly shaped space
The drawers are a good idea as this space is often just wasted!
Re: Attic Robes
I got these finished today as the door knobs turned up. I fitted the trim strip and the cornice and the customer was very happy with them.
I also added a small trim strip to the bottom of the drawers to cover a gap and filled the screw holes.
I am getting the duff runners replaced FOC so will return to fit those in a week or two. Never enough hours in the day!
- Has thanked: 108 times
- Been thanked: 1038 times
- Has thanked: 25 times
- Been thanked: 5 times
Re: Attic Robes
Me too! Weve got that wasted area too (ive got no idea what is behind there, never looked) so im going to build a few drawers! Cheers Mailee for the idea!
