Should have been a freeby
- zedhead
- Has thanked: 64 times
- Been thanked: 19 times
I had some materials left over from a decking job when the punter changed her mind so asked the mrs to lay out the boards and show me what she wanted, I thought she only wanted a bit by the back door!!!... £500 later
- IMG_0987 (Small).JPG (123.19 KiB) Viewed 3978 times
- IMG_0988 (Small).JPG (114.44 KiB) Viewed 3978 times
- IMG_1028 (Small).JPG (111.69 KiB) Viewed 3978 times
Baza
- Has thanked: 1415 times
- Been thanked: 4024 times
Re: Should have been a freeby
I had to turn my laptop on it's side........Wes wrote:Looks well that...I've got a sore neck though Right click on the pic where you've saved it, hit 'rotate', simples
Zedhead.... I hope you haven't put the deck bearers directly on the patio slabs without a DP Membrane??
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
They'd get soaking wet anyway wine-o,on a low level deck I usually sit the joists on concrete blocks on flat and up a few inches from ground level.wine~o wrote:I had to turn my laptop on it's side........Wes wrote:Looks well that...I've got a sore neck though Right click on the pic where you've saved it, hit 'rotate', simples
I know it's not good practice to sit timber on ground but with decking it's sometimes unavoidable.
The main thing to try and avoid is end grain sitting on ground level.
Concur, even if it's just a slab off a patio...get it off the ground wherever possible, a bit of air flow underneath prolongs the life of the deck....steviejoiner74 wrote:They'd get soaking wet anyway wine-o,on a low level deck I usually sit the joists on concrete blocks on flat and up a few inches from ground level.wine~o wrote:I had to turn my laptop on it's side........Wes wrote:Looks well that...I've got a sore neck though Right click on the pic where you've saved it, hit 'rotate', simples
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 569 times
Issi nohoWes wrote:Looks well that...I've got a sore neck though Right click on the pic where you've saved it, hit 'rotate', simples
- These users thanked the author moderator2 for the post:
- zedhead
- zedhead
Sorry about pics I only sussed how to post em today.. Will work it out eventually lolWes wrote:Looks well that...I've got a sore neck though Right click on the pic where you've saved it, hit 'rotate', simples
Baza
- zedhead
Only the front bearers are in place in the pictures the rest went in after that, the ones on the concrete slab are on dpc and the ones on the grass are concrete brick and dpc (I always put em in when the frame is built).... Some of the timbers by the original step are very close to the original slab but I needed to get the step height and the bit down the side (that you can't see) right.... will get the picture malarky sorted eventually lolwine~o wrote:I had to turn my laptop on it's side........Wes wrote:Looks well that...I've got a sore neck though Right click on the pic where you've saved it, hit 'rotate', simples
Baza
- zedhead
Thank you... How did you do that ? I have no edit option on the post with the picturesmoderator2 wrote:Issi nohoWes wrote:Looks well that...I've got a sore neck though Right click on the pic where you've saved it, hit 'rotate', simples
Baza
