tiling outside toilet
- mole81
- Has thanked: 39 times
- Been thanked: 4 times
Im looking to tile and outside loo, thats single skin concrete block...basically the paint has blistered a little but just want to cover over with some cheap(ish) tiles to tidy it up....can i seal or cover this (or do i need to) before tiling and anything else i would need to know?
Cheers!
Cheers!
- Has thanked: 1414 times
- Been thanked: 4019 times
Re: tiling outside toilet
You'll need to remove any loose/flaking paint before tiling, unless you can fix plasterboard...in which case....
Shouldn't need priming, provided you are using a decent quality adhesive (Mapei as one example) and you aren't using huge tiles..and the plasterboard is solidly fixed.
Misunderstood...straight onto block then deffo prime, Screwfix do a Mapei primer 4261c if you have one handy.
just follow the instructions on the bottle.. from what I remember the drying time is about 2 hours depending on ambient temperature etc.
