noticed this on e-bay at only £16.50
http://www.ebay.co.uk/itm/121486532764? ... EBIDX%3AIT
Just noticed that there is aslo a 3/8 stanley set at only £12
http://www.ebay.co.uk/itm/Stanley-20-Pi ... 1856?rt=nc
Stanley 1/2 Socket Set
- Chop
- Has thanked: 304 times
- Been thanked: 219 times
Re: Stanley 1/2 Socket Set
It doesn't come with a metal box, just a tray for putting in a drawer not sure if you noticed that?
It looks for all the world like my Silverline set, which was indeed a good servant. Problem is if you're working on a car and space is tight ratchets like that have a large arc of movement on the lever before the ratchet engages, worst case; you can't tighten/untighten the nut.
Depends what you're using it for and how frequently. If it just occasional it'll probably do, if it's a "buy right, buy once" I would be tempted to push the boat out a little further.
http://www.tooled-up.com/Clearance.aspx ... socket+set There is some good deals here, free delivery and if you use the discount code you'll get a further fiver or tenner off. (See my thread in bargain tools)
