Howdens standard corner carousel
peep
Has thanked: 2 times
Post by peep »
Hi guys
Can anyone help me with an assembly problem with a Howdens standard corner carousel?
It is at
https://www.howdens.com/kitchen-collect ... -carousel/
It does not have assembly instructions in the pack, and it doesn't feature in the Fitted Kitchens manual that Howdens supplied.
There doesn't seem to be a way to lock the supporting rod, as although a metal pin is provided, I can't see how it stays in.
Any help would be gratefully received.
Thanks very much
Phil
Howdens standard carousel.jpg (22.82 KiB) Viewed 7121 times
Chop
Has thanked: 304 times
Been thanked: 219 times
Re: Howdens standard corner carousel
Post by Chop »
Have you got a pic of the part you mean?
Is it the pin to set the height of the pole
or the pin to support the height of the shelf?
These users thanked the author Chop for the post:
peep
:thumbleft:
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
I seem to remember (quite vaguely) that there's a plastic sleeve that fits over the pin once it's in the supporting pole, either that or the shelf provides the sleeve - long time since I did one of those, all the ones I've fitted recently have been the pull-out type.
Phone them up and ask for a set of instructions.
pfb5
Has thanked: 67 times
Been thanked: 106 times
Post by pfb5 »
Does this link help? Turn the sound off and fast forward to 0:50
______
Paul
These users thanked the author pfb5 for the post:
peep
peep
Post by peep »
Thanks guys, for your help.
I got the thing in, with just one of the pins left over. It seems to work fine (at the moment at least)
Return to “Kitchen Fitting”
