Built in wardrobes
- Has thanked: 379 times
- Been thanked: 584 times
Built in wardrobes
Made these for a customer last year.
All made from mrmdf ,nothing fancy just glued,screwed and biscuit jointed together. Beading on doors pinned and glued to match internal doors
All hinges Blum soft closed ,handles to match internel doors
Primed with emulsion(don't tell my friends on the deccy channel),followed by 3 coats of white acrylic eggshell.All sprayed with my airless
Then put together at the top floor of a townhouse
Door fronts hand painted.
Sorry thicko meant to start a new thread ,Please Mr moderator can you moved it for me
- ceilings 013.jpg (115.4 KiB) Viewed 4284 times
- ceilings 020.jpg (111.54 KiB) Viewed 4284 times
- ceilings 021.jpg (104.67 KiB) Viewed 4284 times
- These users thanked the author transitboy for the post (total 3):
- OchAye • ultimatehandyman • steviejoiner74
- Rating: 21.43%
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
Re: Built in wardrobes
Belting job!
- These users thanked the author BillyGoat for the post:
- transitboy
- Has thanked: 855 times
- Been thanked: 994 times
Transit, you have hidden talents.
One question, the following two ;-) please:
1. How flat was the MDF you got? Was it not curved at all (so the doors would show it)?
2. Door edges. Prime/paint/sand and repeat or have you done any tricks to fill the grain?
3. What paint is the final coat (looks like Sikkens Satura or is it gloss)?
Tee hee. You pinched the beading from my once upon a time plain doors but I only have a single box on them.
Very nice.
Very nice.
- These users thanked the author OchAye for the post:
- transitboy
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 569 times
Watch out ... he'll spray you with his hairless sprayer And your glasses can be any colour you choose.moderator2 wrote:Oh yes. no problem at all.
- transitboy
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Very nice - except for the lampshade.
- These users thanked the author ayjay for the post:
- transitboy
- Has thanked: 1 time
- Been thanked: 69 times
You made a nice job of those. Why did you hand paint the doors if you sprayed the rest?
- These users thanked the author mailee for the post:
- transitboy
Never enough hours in the day!
http://www.alanwilley.co.uk/
- ayjay
I had to look twice: I thought the smoke detector had been bagged up.Gadget wrote:
Lampshade?.......I thought it was a lump of cheese!..
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Very nice job!
- These users thanked the author steviejoiner74 for the post:
- transitboy
- Chris Skilbeck
- Has thanked: 132 times
- Been thanked: 238 times
Isn't it always the access and the location that causes the problems - not the work itself ?transitboy wrote: Then put together at the top floor of a townhouse
Beautiful job, Transitboy - (you should really have a word about that lampshade though)
- These users thanked the author Chris Skilbeck for the post:
- transitboy
- Retired
- Has thanked: 2019 times
- Been thanked: 588 times
Top job transitboy; they look very impressive and modern. I too wonder why you sprayed the wardrobes but brushed the door fronts; I would have definitely sprayed the doors which must be a great deal easier and quicker than brushing given they have 36 panels between them? Lovely job though and credit to you. Biscuit jointers are brilliant for this kind of work. How did you align the doors to get them all in the same plane? When I installed our wardrobes I used cross strings from corner to corner pulled tight and when the strings touched in the middle I tightened everything up which worked for me and all the doors fit flush?
I notice you've already started installing your kit? Thanks for sharing.
Kind regards, Col.
Kind regards, Col.
- These users thanked the author Retired for the post:
- transitboy
Sorry to stop you in mid stroke, but from one to another Thank You for moving thismoderator2 wrote:Oh yes. no problem at all.
I thought you might need this , I find it HANDY.
Sorry its taken a bit to get back but was my birthday yesterday.OchAye wrote:Transit, you have hidden talents.
The wood you get now you will be very lucky to get anything flat and straight. Also mdf is the world worst for bending
just remember all ways paint both sides helps and just be careful how you stack it.
If the doors are bent you can get some out with the hinge adjustment
Nothing to fancy just that mate ,might fill with some touprets fine fill. Nine times out of ten don't need it, time they have had 3/4 coats
I have been making wardrobes and units like this for quite sometime, maybe not in mailee skill set but never had complaints.
Like I said just good old jonnos acrylic eggshell.
I have tried all different primers /undercoat and believe it or not no different using ordinary emulsion. So why spend more money then needed
believe it or not I have never had a problem when using it as a primer on mdf.
Very nice.
So was out booking up my coffin,once my deccy mates hear what I use as a primer.
