Bathroom tiling
Bathroom tiling
I've got an old stone built house which doesn't have wall cavities. So the only way to insulate it is to build a studded wall containing kingspan on the inside of every outside wall. I've done 3 rooms already. The next room will be a bedroom which I am converting to become a bathroom. This room has 3 outside walls, each of which is going to be studded.
So I was wondering..... Because this room will be completely tiled, is plasterboard the best covering for the studding? For instance, I could put plywood around the inside of the studding. This would certainly be stronger. But will tiles stick to plywood? I just want to do whatever is best.
Ian
Ian
- philprime
- Has thanked: 77 times
- Been thanked: 247 times
Re: Bathroom tiling
as you are converting it to a bathroom I would use a cement based board to tile on to, rather than plasterboard.
Re: Bathroom tiling
"Cement based board" I didn't know there was such a thing. Sounds good. Thank you.
- philprime
Re: Bathroom tiling
Look at hardiebacker board or no more ply boards
- Has thanked: 19 times
- Been thanked: 21 times
- philprime
Re: Bathroom tiling
kingnewport wrote:A lot more expensive than plasterboard
Yes it is more expensive than plasterboard but won't rot an fall apart unlike plasterboard
If you don't want to go to the cost of using it moisture resistant plasterboard, would be better than standard plasterboard.
Re: Bathroom tiling
The cost isn't so important compared to other things. I'd rather have it right. I just need to be aware of the sheet sizes when i'm building my studding.
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Re: Bathroom tiling
Hardie backer in the wet bits and MR plasterboard for the rest
Bear in mind it also depends how heavy the tiles you're proposing to use are as to what you use
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Bathroom tiling
There is nothing however wrong with mr plasterboard to tile onto,I've ripped out bathrooms that've been up over 20 years and the boarding has been bone dry and sound.
Bear in mind you have to apply blue grit or bond it if you want to plaster over mr plasterboard or you can simply tape/scrim and fill the joints and screwholes.
Plastering on top of the plasterboard greatly reduces the the weight of tiles that it can carry as well.
Re: Bathroom tiling
You could use normal plasterboard but i would recommend using Gyproc MR Plasterboard (green faced).Not only are they moisture resistant but their structure/density is a lot stronger than normal boards as well.
If you're tiling floor to ceiling, make sure the boards are well secured to their background as there will be a fair bit of weight on them.
If you use MR boards, no need to skim them and would prep them with some waterproof coating/tanking before tiling (recommended although not essential).
- Timllfixit
- Has thanked: 146 times
- Been thanked: 209 times
Re: Bathroom tiling
We used it in our bathroom, under the floor tiles. This is the one we used, but others are available. One simply screws it to the wall/floor and tiles direcly onto it. It is very light and easily cut."Cement based board" I didn't know there was such a thing. Sounds good
http://www.dukkaboard.com/How_to_fix_Dukkaboard.php
