Hi all,
Will standard PB, which has been dot and dabbed, be strong enough to hold large porcelain tiles in a bathroom. The tiles are 600x300x10 mm. The tiles are going above and around bath and sink? Many thanks in advance for any help.
Porcelain Tiles on to plasterboard
- Has thanked: 1414 times
- Been thanked: 4019 times
Re: Porcelain Tiles on to plasterboard
You are just about OK with that, but do use a good quality cement based adhesive (Mapei as an example) that states that it is suitable for porcelain.. should come in at about 28/29KG per square metre, max on plasterboard will be about 32 KG per square metre..
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Is the plasterboard skimmed? This will reduce the weight of tile it will hold as well,bare plasterboard holds quite a bit more.
- These users thanked the author steviejoiner74 for the post:
- Felix
Good point. I'd assumed bare.....as the OP didn't mention a skim.steviejoiner74 wrote:Is the plasterboard skimmed? This will reduce the weight of tile it will hold as well,bare plasterboard holds quite a bit more.
- Has thanked: 28 times
Thanks guys for your help, and sorry for my slackness in getting back to you. The PB isn't and won't be skimmed Steve, is it worth putting in a few mechanical fixings as well as dot and dabbing it? Spot on with the weight of the tiles too Wineo, very impressed!
Definitely worth it. Better safe than.........Felix wrote:The PB isn't and won't be skimmed Steve, is it worth putting in a few mechanical fixings as well as dot and dabbing it?
