Lidl 20th April Tool offers
boxedin
Has thanked: 61 times
Been thanked: 319 times
Post by boxedin »
http://www.lidl.co.uk/en/our-offers-2491.htm?id=533
18v lion sds hammer drill £50
sabre saw £30
paint and mortar mixer £40
Portable electric compressor £50
10w led rechargeable worklight £25
plus some handtools
These users thanked the author boxedin for the post:
p4ult
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Re: Lidl 20th April Tool offers
Post by steviejoiner74 »
The magnetic tool strips look very handy! :thumbright:
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Post by London mike 61 »
Thanks for that, the £40 mixer drill looks good to me. I've been meaning to get another mixer drill and for this sort of money it will do me.
I will give it a review when we ( eventually) move house and have to make good the plaster after all the knocking about we plan to do.
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
London mike 61 wrote:Thanks for that, the £40 mixer drill looks good to me. I've been meaning to get another mixer drill and for this sort of money it will do me.
I got one a couple of years ago and it's been superb. Regularly use it for mainly mixing up tile adhesive.
r055c
Banned- Hacked account
Has thanked: 6 times
Been thanked: 6 times
Post by r055c »
Anybody with experience using that sabre saw? Been toying with the idea of getting one for a while
p4ult
Has thanked: 12 times
Been thanked: 38 times
Post by p4ult »
If I remember when passing I'm going to get a couple of those magnetic strips
Has thanked: 1415 times
Been thanked: 4024 times
Me too... though regulating the speed via the trigger switch can be a bit hit and miss...
I certainly wouldn't use it for mixing/stirring paint........ :shock:
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
steviejoiner74 wrote:The magnetic tool strips look very handy! :thumbright:
They're good. I got some the last time they had them.
r055c wrote:Anybody with experience using that sabre saw? Been toying with the idea of getting one for a while
I've had one for years, but I've never really got on with it. Mine's a Bosch (green) It's OK (but only just) with a wood cutting blade, but the metal cutting and tree lopping blades don't work at all for me. To be honest every time I've used it I've felt as if I'd have been better with a sharp handsaw. :)
r055c
Post by r055c »
So what u say is it's not worth it. I have an old fence to dispose of the plan was to cut the fence in small parts using the sabre saw
Dave54
Post by Dave54 »
It may be me, but I've had a saw of similar type for years and never really got on with it. Used decent Bosch blades in it and I've been unimpressed. Blades stick in thicker material and you end up fighting the machine as it tries to push out of the cut. It's OK in thinner stuff. I have an idea that as with jigsaws then a machine with orbital action may be the answer. I don't think the Parkside machine has that.
As I say I haven't used that particular tool all that much really. Someone else with more experience of the type may be along.
Has thanked: 736 times
Been thanked: 2341 times
that happens when the wood tightens onto the blade usually because off weight or its wet
if you use a blade with offset teeth it will be far less likely to bind up
if you are cutting something heavy make sure the weight isnt closing the gap up by supporting the timber
if your cutting say a branch cut the top surface as that surface will be opening out with the weight
rather than underneath that will be closing up thats assuming its still on the tree
if you are cutting the same branch say on a bench and the only support is at each end then you would expect the underneath will be opening out ??
well yes it might all depends on the way the tree grows
Dave54
boxedin
Post by boxedin »
Just spotted this on Hotukdeals
Buy either the Sun, The Express, The Daily Record, The Telegraph or the Daily Mail on Sat 25th April and you will find a copy of Lidl News with a voucher on the back page saving you £5 when you spend £40.
So assuming that there are tools left in your store then an extra £5 off possible always assuming the bill comes to £40 or more of course.
Dave54
Post by Dave54 »
Thanks mate, but I've done all that, used the right blades for different jobs etc., and I still don't like that type of saw. Maybe I expect too much. Perhaps I'll get some more blades of a different type and try them.
Dickie
Has thanked: 893 times
Been thanked: 729 times
Post by Dickie »
Varies pliers available at Lidl for around 2 quid. I'm always losing pliers so bought a couple of pairs.
Check it out. Oh, and don't forget their bakery products very, very good & great value too!!
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
p4ult
Post by p4ult »
Got mine up!
Return to “Bargain Tools”
