Multi tool blades
stevewestern
Has thanked: 114 times
Been thanked: 97 times
Re: Multi tool blades
Post by stevewestern »
So, how well do they cut and how long do they last...?
marcusjkw
Has thanked: 48 times
Been thanked: 26 times
Post by marcusjkw »
Yep, mine arrived the next day, except I got the open-ended type for Dewalt, not tested them yet
Lancashire Building, Roofing, Joinery & Maintenance. Marcus Whitehead Property Services.
http://www.marcuswhitehead.co.uk
http://www.facebook.com/joinerbuilder
Bill Darr
Has thanked: 18 times
Been thanked: 44 times
Post by Bill Darr »
Any update on these blades?
getthewheelsinline
Has thanked: 224 times
Been thanked: 182 times
Post by getthewheelsinline »
Bought 10. Undercut some door frames no problem. As they are long teeth the side teeth tend to chip off if caught on brickwork - too be expected though. At £1.40 each they are classed as disposable... Good value for money.
These users thanked the author getthewheelsinline for the post:
stevewestern
Has thanked: 738 times
Been thanked: 2346 times
getthewheelsinline wrote:Bought 10. Undercut some door frames no problem. As they are long teeth the side teeth tend to chip off if caught on brickwork - too be expected though. At £1.40 each they are classed as disposable... Good value for money.
classify your blades as good worn and knackered
use the good blades to cut within a few mm off a wall hostile surface or suspected nails then finish with the knackered blades if in doubt use a part worn blade then a knackered blade :huray:
stevewestern
Thanks for the update !
marcusjkw
Post by marcusjkw »
yeah, they seem okay to me too. Not tried them out for any length of time, but then again none of the other brands last that long anyway
Bob225
Has thanked: 105 times
Been thanked: 880 times
Post by Bob225 »
old blades - I sharpen mine up and use them as a scrapers ideal for removing tiles or the kids stickers that weld them self to everything with the added benefit of the multi-tool
Return to “Bargain Tools”
