Luxury Vinyl tiles in the bathroom
el_mag
Has thanked: 5 times
Post by el_mag »
We have a sheet vinyl floor in our bathroom which the 'boss' wants changed to Limestone vinyl tiles. From what I have read once the sheet vinyl is removed, it needs 6mm WBP ply screwed at regular intervals. Special PS adhesive and then the tiles.
1) Do I need to put any DPM sheet under the ply?
2) Does the top of the ply need to sealed/feathered?
3) Are the vinyl design strips glued at the same time as the vinyl tiles or do use spacers and fill them later??
4) What colour grout strips look best with Limestone tiles?
5) The 'Boss' wants cream strips but I wonder whether the vinyl grout strips get dis-coloured just like normal grout??
Many thanks for answering the queries.
Wes
Wood Flooring Installer
Has thanked: 379 times
Been thanked: 565 times
Re: Luxury Vinyl tiles in the bathroom
Post by Wes »
el_mag wrote:We have a sheet vinyl floor in our bathroom which the 'boss' wants changed to Limestone vinyl tiles. From what I have read once the sheet vinyl is removed, it needs 6mm WBP ply screwed at regular intervals. Special PS adhesive and then the tiles.
What's the sub-floor, chipboard/floorboards/concrete/ashpalt etc?
el_mag wrote:2) Does the top of the ply need to sealed/feathered?
Yes. You'll need the use something like Ardex Feather or similar on all seams and screw/nail holes. Then it'll need rubbing down.
el_mag wrote:3) Are the vinyl design strips glued at the same time as the vinyl tiles or do use spacers and fill them later??
You'll glue the design strips as you go.
el_mag wrote:4) What colour grout strips look best with Limestone tiles?
Personal choice really IMO. I'd say a darker grout to accentuate the tiles but you could perhaps go for a light grey :dunno: It would be worth getting samples if possible to help with the choice before you buy.
el_mag wrote:5) The 'Boss' wants cream strips but I wonder whether the vinyl grout strips get dis-coloured just like normal grout??
Depends on the usage. They will dis-colour over time and with it being a light grout strip, you may see dirt grab in the seams between the tiles and the grout. A slightly darker colour would help.
These users thanked the author Wes for the post:
el_mag
el_mag
Post by el_mag »
Wes,
Thanks for your reply. The sheet vinyl is on top of floor boards.
I had a look at Ardex feather finish, it seems to come only in bags of 11 kg. Is there any other alternative as it's only a small area.
I agree that grey would probably be better with limestone tiles as i was worried the light grout strips would get dirty.
Thanks again
NorthantsBen
Has thanked: 1 time
Been thanked: 2 times
Post by NorthantsBen »
Ultra floor patch it comes in 5kg bags.
I used to use it all the time when fethering ply etc ready for lvt / vinyl.
I like ultra products I use there two part latex and quick repair too.
These users thanked the author NorthantsBen for the post:
el_mag
Wes
Post by Wes »
No need for a dpm then el mag :thumbright:
el_mag
NorthantsBen
Has thanked: 1 time
NorthantsBen wrote:Ultra floor patch it comes in 5kg bags.
I mean feather it not patch it... :lol:
el_mag
Post by el_mag »
Another quick question guys - Do I need to put a primer on the plywood before I put the Ultra-floor feather it?
Many thanks
Wes
Post by Wes »
el_mag wrote:Another quick question guys - Do I need to put a primer on the plywood before I put the Ultra-floor feather it?
Many thanks
No.
El-mag, as with all such products, they'll be instructions on application on the side of the tub/bag..
el_mag
