Windows 10 Loaded
- Has thanked: 100 times
- Been thanked: 877 times
Re: Windows 10 Loaded
All of the MS data acquisition can be turned off, also turn off connect to hotspots and contacts wifi - fail - default screen saver is random pictures from the pictures folder
one handy feature is virtual desktop (acts the same as multi monitor setup)
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- joinerjohn
- Has thanked: 17 times
- Been thanked: 315 times
- thescruff
The only way I can turn it off is by pressing the power button on the desk top.
- Has thanked: 30 times
- Been thanked: 121 times
Bit shocked to read on here about antiviruses not compatible, I looked on my PC and couldn't find mine, didn't even think of checking it was ok
I downloaded the latest version from Kaspersky and it is ok and even recognised the licence which saves me trying to remember the password.
virtual desktop
Windows Key + Ctrl + D – Create a new virtual desktop and switch to it
Windows Key + Ctrl + F4 – Close the current virtual desktop.
Windows Key + Ctrl + Left / Right – Switch to the virtual desktop on the left or right.
shutdown from the desktop press and hold Alt + F4 and up pops a box, simples
Security wise. start button - settings - privacy
- thescruff
- thescruff
Tried alt/f4 and indeed it shut down but doesn't turn the power off.flash22 wrote:virtual desktop
Therefore it comes back to life about a minute later, as it does in sleep mode, the only way I've found to power down is to press the off button on the tower.
- Has thanked: 1414 times
- Been thanked: 4019 times
thescruff wrote:Tried alt/f4 and indeed it shut down but doesn't turn the power off.flash22 wrote:virtual desktop
Hit start (windholes key)
Bottom left ish is a Power option, click on that and select shut down.
- thescruff
Yes Mike and a few minutes later the screens light up again, the shut down button doesn't turn the power off, red light still on.
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
joinerjohn wrote:That's one thing I'm concerned about. The fact that Microsoft can actually read private emails, or (even worse) personal stuff kept in private folders. In other words, they could access my bank account, CV, all the stuff on my computer. Who's to say Microsoft don't have any dodgy employees, willing to sell personal data on? Do you trust them completely?darrenba wrote:Well this is:
Is this serious JJ?
Do you think people at MS have a secret button to open up people's files?
If you don't trust the OS you are running - don't use it! It's all getting a bit too 'the man is watching me' here.
BG
- BillyGoat
- Troll Headbutter
It's likely power management for the computer Scruff (the way it's set in the BIOS, would be my best guess).thescruff wrote:Tried alt/f4 and indeed it shut down but doesn't turn the power off.flash22 wrote:virtual desktop
I had a similar issue a while ago with my laptop it was not set to S3 (is it S3 or S1? I forget....someone else might know!) and caused the same thing.
Failing that, my second guess would be old chipset drivers that have not played ball during the upgrade process. What computer/motherboard is it - Intel based?
If it is, they are a LITTLE bit behind the ball at the minute due to the release date brought forward - there will be lots of updates coming soon.
BG
thescruff wrote:Yes Mike and a few minutes later the screens light up again, the shut down button doesn't turn the power off, red light still on.
Works for me ??
- BillyGoat
- Troll Headbutter
flash22 wrote:All of the MS data acquisition can be turned off, also turn off connect to hotspots and contacts wifi - fail - default screen saver is random pictures from the pictures folder
All of this stuff has been around for as long as time - why is it suddenly a problem? It's used for the "there is a fix for problem X" and the bugs that people whinge about.
Make sure you turn it off in everything else too............(anyone use virus submission when it detects malware - SHOCK!!!).
BG
