Hello all, just wondering if anyone has used Jackoboard as a tile backer?
If yes, how did you get on? Any hints/tips?
I plan to use it on a primed brick wall. Will be applied with the appropiate adhesive and after the bond has set, mechanically fix with suitable screws and washers. The tiles I'll be fitting are 60*30.
Jackoboard reviews?
- Has thanked: 1414 times
- Been thanked: 4019 times
Re: Jackoboard reviews?
Never heard of *Jackoboard* is it a cement based board similar to aquapanel ??
Quoting a local trader "Its more or less the same as the Marmox board - extruded polystyrene with a 'special' cement coating on either side".
Here is a link with further information and install demo:
https://www.youtube.com/watch?v=xo27i6es-vU
