Drilling holes for fixings into porcelain tiles
- Has thanked: 157 times
Whats the best diamond drill bits for drilling holes in porcelain tiles? Need to do around 30 holes.
Sent from my SM-G901F using Tapatalk
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Drilling holes for fixings into porcelain tiles
What size of hole and what is the hole for?
Shower fixing kit, shower rail, shower screen, toilet to floor, vanity basin unit, towel radiator. Size of hole to fit a red wall plug.
- steviejoiner74
In that case then try this,I've used this before and it performed a lot better than more expensive brands by some distance.
- image.jpeg (142.29 KiB) Viewed 2727 times
- These users thanked the author steviejoiner74 for the post:
- Sparky70
- Has thanked: 104 times
- Been thanked: 490 times
I tend to get my diamond drills from my local tiling shop for about 1/2 that price. To get the best life out of diamond drills you need to make sure you don't get them too hot.
- Colour Republic
- Has thanked: 263 times
- Been thanked: 544 times
By far the most cost effective solution - http://www.atsdiamondtools.co.uk/node/12
You'll get 15-20 holes out of each bit if you use them correctly, even more if you look after them.
- These users thanked the author Colour Republic for the post (total 3):
- darrenba • Sparky70 • steviejoiner74
- Rating: 21.43%
- steviejoiner74
Thanks for the link I very rarely have to drill into tiles but at that price I'm going to buy a few sizes for future use. Great value for money!Colour Republic wrote:By far the most cost effective solution - http://www.atsdiamondtools.co.uk/node/12
It says on their website that you can hold a wet sponge against the drill bit to keep cool, how is this acheived as not sure?darrenba wrote:I tend to get my diamond drills from my local tiling shop for about 1/2 that price. To get the best life out of diamond drills you need to make sure you don't get them too hot.
