recipricating saw
This forum is for reviews of Budget power tools such as B&Q / Wickes own brand, Direct power / Titan / challenge / Performance power / Erbauer / Skill/ Bosch Green / Black & Decker
caravan72
Has thanked: 31 times
Been thanked: 14 times
Re: recipricating saw
Post by caravan72 »
caravan72 wrote:Hi folks, looking aroung some people think this these blades would be good for tree roots.
http://www.screwfix.com/p/bosch-recipro ... of-5/71339
Got these baldes today hope they fit the erbauer? I expect there must be a univesality to these things! I hope.
Rorschach
Has thanked: 116 times
Been thanked: 1042 times
Post by Rorschach »
Yes recip saw blades are universal, or at least they should be.
caravan72
Post by caravan72 »
Cheers Rorschach, Just tried a blade in and it fits, now maybe you could explain one of the instructions!
In the book it says:
Removing saw blade.
Rotate the tool-free blade clamp lever (4) in clockwise direction and hold. Pull the blade out of the blade holder and release the clamp lever (4)?
I pulled the clamp lever down and the blade came out ok but I can't figure out what they mean by rotating it! doesn't seem to move in any direction rather than down or up! am I missing something?
Seemed easy enough to assemble, also would you reccomend using those vibration type gloves with this tool?
Thanks in advance.
Has thanked: 738 times
Been thanked: 2347 times
it probably is a bad translation try pivot down/up rather than rotate
yes the lever will be rotating around the pivot so rotating as far as thats concerned
caravan72
Rorschach
Post by Rorschach »
Some clamps rotate, others push down. I think their instructions are wrong.
caravan72
caravan72
Post by caravan72 »
big-all wrote:it probably is a bad translation try pivot down/up rather than rotate
Makes sense.
Cheers
caravan72
Post by caravan72 »
Rorschach wrote:Got an angle grinder? Just shorten the blade if needed.
On studying the intructions it looks like you can lenthen the saw table and this would give me the oprtunity to shorten the blades operating area, nice option!
Rorschach
Post by Rorschach »
Yes this is common so you don't wear only one area of the blade which can happen if you cut material thinner than the blade is specified for, though to be honest most of the time I have not needed to move the "shoe" when using mine. For special jobs in tight places I have trimmed down an old blade to get it to fit, a couple of minutes getting out the angle grinder was better than doing it by hand! lol
_Chris_
Has thanked: 181 times
Been thanked: 2 times
recipricating saw
Post by _Chris_ »
Rorschach wrote: Wed Mar 09, 2016 7:31 am Got an angle grinder? Just shorten the blade if needed.
Sounds good. How would you shorten the blade for an angle grinder though?
Has thanked: 47 times
Been thanked: 2600 times
recipricating saw
If you read the whole topic, I will believe you will find that it has been taken out of context, not to mention it was said 8 years ago The subject is about tree root removal, so the question was "Got an angle grinder?" then back to the main point of a reciprocating saw, "shorten the blade if needed"
These users thanked the author Someone-Else for the post (total 2):
moderator2 (Fri Nov 22, 2024 6:32 pm) • Rorschach (Fri Nov 22, 2024 8:47 pm)
Rating: 14.29%
Locked
Return to “budget power tools ”
