Got these baldes today hope they fit the erbauer? I expect there must be a univesality to these things! I hope.caravan72 wrote:Hi folks, looking aroung some people think this these blades would be good for tree roots.
http://www.screwfix.com/p/bosch-recipro ... of-5/71339
recipricating saw
- Has thanked: 31 times
- Been thanked: 14 times
Re: recipricating saw
- Has thanked: 108 times
- Been thanked: 1038 times
Cheers Rorschach, Just tried a blade in and it fits, now maybe you could explain one of the instructions!
In the book it says:
Removing saw blade.
Rotate the tool-free blade clamp lever (4) in clockwise direction and hold. Pull the blade out of the blade holder and release the clamp lever (4)?
I pulled the clamp lever down and the blade came out ok but I can't figure out what they mean by rotating it! doesn't seem to move in any direction rather than down or up! am I missing something?
Seemed easy enough to assemble, also would you reccomend using those vibration type gloves with this tool?
Thanks in advance.
Removing saw blade.
Thanks in advance.
- Has thanked: 735 times
- Been thanked: 2339 times
it probably is a bad translation try pivot down/up rather than rotate
yes the lever will be rotating around the pivot so rotating as far as thats concerned
Some clamps rotate, others push down. I think their instructions are wrong.
Makes sense.big-all wrote:it probably is a bad translation try pivot down/up rather than rotate
Cheers
Rorschach wrote:Got an angle grinder? Just shorten the blade if needed.
On studying the intructions it looks like you can lenthen the saw table and this would give me the oprtunity to shorten the blades operating area, nice option!
Yes this is common so you don't wear only one area of the blade which can happen if you cut material thinner than the blade is specified for, though to be honest most of the time I have not needed to move the "shoe" when using mine. For special jobs in tight places I have trimmed down an old blade to get it to fit, a couple of minutes getting out the angle grinder was better than doing it by hand! lolcaravan72 wrote:Rorschach wrote:Got an angle grinder? Just shorten the blade if needed.
- Has thanked: 181 times
- Been thanked: 2 times
- Has thanked: 47 times
- Been thanked: 2575 times
recipricating saw
If you read the whole topic, I will believe you will find that it has been taken out of context, not to mention it was said 8 years ago The subject is about tree root removal, so the question was "Got an angle grinder?" then back to the main point of a reciprocating saw, "shorten the blade if needed"
- These users thanked the author Someone-Else for the post (total 2):
- moderator2 (Fri Nov 22, 2024 6:32 pm) • Rorschach (Fri Nov 22, 2024 8:47 pm)
- Rating: 14.29%
