Gazebo Rebuild
PhilCop
Has thanked: 13 times
Been thanked: 13 times
Gazebo Rebuild
Post by PhilCop »
When we bought our Finca/House, there was a gazebo alongside the swimming pool, but the workmanship left a lot to be desired, it was just a matter of when, not, if, it was going to fall down, therefore this was a project of some urgency, which got underway in the new year of 2015.
My Father-in-law was staying with us at the time, and gave me a hand in dismantling the old gazebo
Even from this photo you can see how bad the joinery was!
I took it all down, leaving just the four corner posts, which were to be the basis for the new Gazebo, I had all the framework timber (mahogany), but as we finished, it was obvious that work had come to a halt, one of the corner posts was rotten in the top half. I didn't want to have to dig out the post, as that would have meant re-laying the base, and I did not have the money to do that. I cut the post down to solid timber, and once the Holiday period was over, I had a metal collar made, which I used to join new timber to the old. Unfortunately by this time I was now working on my own again.
Humping the big supporting beams up was no joke, but with a bit of ingenuity, ropes and my platform ladder, I managed to get in place and bolted securely.
but before raising the cross beams, I mortice and tenoned the riser into the beam, and put a bolt through the joint to make sure it was going nowhere.
Then came the ridge beam, which sat in a slot cut in the riser, and bolted, followed by the rafters.
the first layer of roofing was T&G pine 1/4” thick planks, which I nailed with my air nail gun. That wasn’t so bad, as I could do most of the work from a ladder, after which I fitted the barge boards. Then I had to felt it, and this took some time, because I had to do it when the sun was in, as soon as the sun comes out the tar melts and seals the felt to whatever it is in contact with. I battened the roof as I felted it, to avoid having to crawl around and damage the felt. It was bad enough being up there in the first place…I hate heights, and was crawling around like a baby, I just hope none of the neighbours had their camera out!
Then came the roofing sheets, however for these roof sheets, they want you to use wires to fix them, they come attached to a plastic top, which you feed through a drilled hole in the roof and you then tie them down to a nail, I think these are horrible, and visually displeasing, so I bought the Unduline screw fixers, the problem with that is that the stainless steel screws supplied were too long for these sheets, so I changed them all for drywall screws.
Once that was done, it was just a case of installing the guttering, and electrics, job done, and unlike the olf Gazebo, I am happy that this one will give us many years good use.
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Re: Gazebo Rebuild
Very smart :thumbright:
It looks like you live in an idyllic setting, there is some nice scenery in some of those shots!
Argyll
Has thanked: 1180 times
Been thanked: 580 times
Re: Gazebo Rebuild
Post by Argyll »
ultimatehandyman wrote:Very smart :thumbright:
And I bet the marching powder is dirt cheap ha ha ha :thumbright:
PhilCop
Re: Gazebo Rebuild
Post by PhilCop »
It is is a great location at the moment, unfortunately the Town Hall are short of funds, and have given the green light for a load of new buildings to go up as holiday lets, which will block some of our views, and increase the security problem... I was going to fight it, but with corruption as rampant as it is in Colombia, I would be wasting my time, hopefully we have another year or so, before we notice the change.
These users thanked the author PhilCop for the post:
Argyll
Re: Gazebo Rebuild
Post by Argyll »
PhilCop wrote:
ultimatehandyman wrote:I was going to fight it, but with corruption as rampant as it is in Colombia, I would be wasting my time
It's just as rife here mate but they hide it better or rather spin it better.
The Virgin rail franchise fiasco
TTIP
MP's expenses scandal
I could go on
Return to “Show Case Gallery”
