IRWIN Record SP5 Jack Plane 50mm (2in) £20
- Argyll
- Has thanked: 1183 times
- Been thanked: 581 times
- Has thanked: 58 times
- Been thanked: 18 times
Re: IRWIN Record SP5 Jack Plane 50mm (2in) £20
Do you thing it will worth it? I don't mean money, since it's ridiculously cheep.
- BANNED
- Has thanked: 125 times
- Been thanked: 115 times
I'll let you know. Ordered one (thanks for link). I was given my present 'craftsman' plane from Wilko as a gift as most of my tools are on the other side of the planet - and it is crap, pure crap. Works sometimes but steel doesn't hold an edge and it doesn't stay set in place, ever, I've been meaning to replace it for months. Been using a good old surform in preference to it for many jobs (don't laugh) but that won't do a proper jack plane's job. A jack plane like this is a basic tool and I reach for one automatically often This should be much, much better if it is a proper Irwin Record jack.
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
The irwin record stuff is crap now,just like the irwin marples chisels. The steel is Chinese and not the Sheffield steel it was years ago. Maybe worth a punt at 20 quid but I'd rather buy a second hand quality plane off fleabay that had Sheffield steel blades for less money.
- These users thanked the author steviejoiner74 for the post (total 2):
- Argyll • Dave54
- Rating: 14.29%
- Has thanked: 32 times
- Been thanked: 807 times
I've got old ones. god knows how old they are like. ones got a square topped blade like. i bought a number 4 1/2 and a number 5 1/2 as i prefer the slightly heavier sizes
- Argyll
If it's just the blade quality can't you just buy a new blade or are they all Chinese crap now?steviejoiner74 wrote:The irwin record stuff is crap now,just like the irwin marples chisels. The steel is Chinese and not the Sheffield steel it was years ago. Maybe worth a punt at 20 quid but I'd rather buy a second hand quality plane off fleabay that had Sheffield steel blades for less money.
you'd be able to source a better blade no problem. as said above the irwin marples chisels are absolutely bloody rubbish. way too soft.
- BANNED
Bugger, I went on the name I used to know - should have waited. Oh well it just can't be worse than the Wilko one ....?
- Has thanked: 893 times
- Been thanked: 729 times
I've been looking at second hand block planes SJ. But I'm undecided which one would be best for general use, skirtings/facings etc. Can you give me your recommendation for a Stanley or Record & what number?steviejoiner74 wrote:The irwin record stuff is crap now,just like the irwin marples chisels. The steel is Chinese and not the Sheffield steel it was years ago. Maybe worth a punt at 20 quid but I'd rather buy a second hand quality plane off fleabay that had Sheffield steel blades for less money.
Cheers mate....
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
The Plumbers Anthem
Gas Safe RGI
- steviejoiner74
Here is the same one I use,great for dressing mitres on facings and skirting and nice for chamfering material as well. I bought mine of fleabay several years ago for around 25 quid and it came with the origional blade which holds an edge nicely and has lasted me well.Dickie wrote:I've been looking at second hand block planes SJ. But I'm undecided which one would be best for general use, skirtings/facings etc. Can you give me your recommendation for a Stanley or Record & what number?steviejoiner74 wrote:The irwin record stuff is crap now,just like the irwin marples chisels. The steel is Chinese and not the Sheffield steel it was years ago. Maybe worth a punt at 20 quid but I'd rather buy a second hand quality plane off fleabay that had Sheffield steel blades for less money.
Cheers mate....
- image.jpeg (128.42 KiB) Viewed 4395 times
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
It isn't just the blade quality - it's the adjuster which they have cheapened, the nasty bent steel chip breaker which never beds properly, the lever cap which uses a screw instead of a cam lever, the nasty plastic handle and front knob instead of wooden ones, the poor machining and assembly generally, in particular the ropey way the frog mates to the main body. Picky? Moi? As to blades, the absolute best replacement blades I've come across are made by a bloke called Ray Iles (one of Ashley Isles's sons - he of carving tool fame) IN THE UK from O1 carbon steel and available through places like Workshop Heaven. Ray's irons really hold an edge well. For straight replacement irons you need to go for the thiner (2.5mm thick) blades. There are thicker blades but they require a bit of butchery to the plane (not recommended for the faint hearted, therefore). For a #4 or #5 plane that would be the RI021S. Teamed-up with a thickwe chip breaker such as the Quangsheng 2in one which will stiffen the blade considerably (makes for smoother planing) you have a far better plane - but at a great increase in price. Notice that a decent blade and a good chip breaker cost twice as much as your cheap plane - maybe that's saying something? I've done these swaps with a number of my working planes as they are all 50+ years old, the blades were shot and I wanted to keep them in use, but if I were buying new I'd probably go for something like a von Berger #5 which is a Quangsheng by another name. Downside is that they are £100, and whilst they are no Lie-Nielsen or Clifton they are a helluva lot better than any of the cheaper planes I've seen and being made from cast steel as opposed to cast iron they don't break if you drop them on a concrete floor (been there, done that - ever seen a grown man cry? )Argyll wrote:If it's just the blade quality can't you just buy a new blade or are they all Chinese crap now?
- BANNED
Now I am really unhappy.
I bought it by name as they used to be good and also because they are usually 65 quid or more. That is not cheap. I accepted it was a promotional offer as it is annual catalogue time for them. Oh well. Pay for mistakes, should have researched better, I usually do but assumed it would be same.
- getthewheelsinline
- Has thanked: 224 times
- Been thanked: 182 times
if you've an axminster near you swing by and check out their range. they look canny. though i must say I've not really had a proper look.
last time i was in axminster i had a play with some lie-nielsen planes. pretty nice like. but pretty expensive too
- Has thanked: 1300 times
- Been thanked: 1175 times
They look lovely fin. Almost too good to use. Never tried one, but they say they are excellent.fin wrote:if you've an axminster near you swing by and check out their range. they look canny. though i must say I've not really had a proper look.
