Kitchen Refit - Horror discoveries...
- BANNED
- davek0974
- Has thanked: 103 times
- Been thanked: 20 times
What bothered me was that i dont feel two wraps of pvc tape are adequate insulation on a 32A circuit, the screws were not particularly tight so it seemed like a good point for some melting to be going on.
The shower spur really bothered me due to the lack of protection for the shower and myself in a fault. If we had changed to a normal shower, which the size of wiring dictates is ok, it would blow the breaker when the cooker is on
Its not the fact that the mess exists its just that it really was not that hard to do it correctly, or if not correctly, a 1000 times safer.
It turns out that the owners had a flood upstairs which wrecked the kitchen and the work was done under the insurance claim.
Dave
Dave
DIY - Joining things together to make stuff ;)
https://davekearley.co.uk/
- Gas/Heating Expert
- Been thanked: 9 times
- davek0974
Bit more found after more stripping out...
The 6mm T&E went straight into the bottom of the hob, no connection box or heat resistant flexi. It was quite black & brittle when i pulled it out.
Nice
Nice
- village idiot
- diesel demon
- Has thanked: 104 times
- Been thanked: 104 times
at least he used connectors, the numpty in the house before us just used the "twist & tape" method to extend the cooker cable, using 2.5mm2 T&E
i love being married
it's great to find that one special person that you want to annoy for the rest of your life
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
Still Yes Highland
- davek0974
Here we go again...
Ello, ello, ello, what goes on here...
Stripping anaother wall reveals the excellent twist and tape ring main extension.
I love the state of the wiring in this kitchen, so glad i'm ripping it all out.
Dave
Dave
- davek0974
Spent a good couple of hours trying to suss out how the c/heating boiler was wired up.
Has two cables going in, one should be permanent supply, the other goes out to the pump, seems nice and easy.
Why the f*ck would some monkey take the live feed from one cable and the neutral & earth from the other cable with the other two odd wires going to the pump??
It makes no sense as it's the same number of wires, just makes it impossible to work on the boiler safely etc. I'm not going to change this at present as the other ends go into a strip-block wiring jumble in the cylinder cupboard. I'll leave some notes at each end and re-wire the whole lot when i get onto the heating system. I don't want to add to the workload at present.
Bloody idiots.
Dave
Bloody idiots.
Dave
surely once the fused spur is off to the boiler, then is safe to work on?davek0974 wrote:Spent a good couple of hours trying to suss out how the c/heating boiler was wired up.
Bloody idiots.
Dave
You have already seen is obvious that the N & E comes from a different cable than the Perm Live.
No problem at all.
I'm guessing there are 2 x 2+E to provide
Perm Live
Pump Live
Boiler Live
Neutral
2 x earth.
is fine the way its wired, if not logical.
- davek0974
Still cant see why split it.
I have since found some info on the boiler.
It shows three cables:-
Pump Control
Boiler supply
Boiler control
This would match what you state HintonHeating, I've only got two cables, four cores in total (not counting earths).
That explains things a bit more, but i would still have taken one complete cable for the supply, then used the other for pump and boiler control. The pump neutral must come from the wiring mess upstairs.
Wierd way of doing it.
Dave
Pump Control
Boiler supply
Boiler control
Dave
- davek0974
Yes, ok,
but why split the live feed across two cables. Surely it makes sense to use one T&E to supply the permanent live feed, then the other T&E as the control cable running the pump and boiler?
ps, only one cable is earthed
Dave
Dave
