Router tables?
Bludall
Forum Chatterbox
Has thanked: 39 times
Been thanked: 7 times
Post by Bludall »
That's the one I looked at this afternoon. What bumps the cost up? Are the pricier ones more accurate or belt and braced (safer)?
Failure means you just didn't get it right yet!
Louise
peter c
Has thanked: 6 times
Been thanked: 16 times
Post by peter c »
I've got the one from Axminster looks similar to Hitch's. It is a tad awkward to set up but once it is the results are quite good. I found it a bit fiddly to fit my old router (B&D), but as I only use the table now and again it is adequate.
Peter C
The end justifies the means
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Id imagine its things like the quality and accuracy of the mitre shot/guide, finish of the tabletop, number of accessories...
peter c
Post by peter c »
I have only used mine for small jobs as the router is not very powerful. For bigger jobs I have a half inch router which is a bit of a brute ::b
Peter C
Hitch
Post by Hitch »
I use my draper expert 1/4" (identical to trend t5) mostly, but for the bigger jobs, whack in the Hitachi..
Another thought, a fine height adjuster on your router, screw type, is very usefull for adjusting cutter height :thumbright:
Bludall
Forum Chatterbox
Post by Bludall »
My oh has American plans for a wooden bicycle. He's also got lots of musical instruments like an Appalachian dulcimer, mandolin and serpent on the go. On top of that there's a partly welded bit of a recumbent bike lying around. I thought the router table may speed things up. It'd not be used 24/7 but it would be good to get one. I'll have to measure the router base plate to see if it'd fit.
Louise
Hitch
Post by Hitch »
He wont be able to weld up the rest of the bike with a router table.... :lol:
Bludall
Forum Chatterbox
Post by Bludall »
No but that is one of the jobs. :lol:
Louise
peter c
Post by peter c »
Thats a good point Hitch. I have the Trend micro adjuster that I have fitted (bodged) to the B&D. Marvellous what you can do with a set of taps and dies :thumbright:
Looking at the T3 it is similar to the B&D although the Trend has a square base plate and mine has a rounded one
Peter C
Bludall
Forum Chatterbox
Post by Bludall »
::b ::b ::b ::b ::b ::b
My oh has bought himself a routing table! I think he must be telepathic! Now I'm back to the drawing board.
:roll:
Louise
Has thanked: 740 times
Been thanked: 2355 times
does he have a decent set of router cutters!!!!!!
OnlineOnline
Bludall
Forum Chatterbox
Post by Bludall »
The router has collets for 1/4" and 1/2 " cutters, so he has a couple of boxes of cutters for it.
Louise
with patience you can make some nameplates
i have "big all's pad " on my workshop in a name plate with half a octigon shape at each end
http://www.rutlands.co.uk/cgi-bin/psProdDet.cgi/1256
OnlineOnline
Bludall
Forum Chatterbox
Post by Bludall »
We've got a similar place near to us.
http://www.craft-supplies.co.uk/cgi-bin/psProdSrch.cgi
Louise
Return to “Tool Talk”
