Biscuits again
- Has thanked: 12 times
Biscuits again
Would someone be able to tell me the best glue to use for joining a biscuit? I didnt know whether no more nails etc would be best but not sure if its water based. Didnt know whether PVA would do the job as I think its water based. thanks again
- Has thanked: 736 times
- Been thanked: 2341 times
all depends on what your joining !!
how stable the timber is !!!
how strong it needs to be !
and weither it can be seen or not!!
cut a slot the full length avoiding the 15mm either end or any point you are going cut it at
every 4 inches is fine 8 inches if it isnt to structural
biscuts then biscuit lenth gap if high load or warping
continuose for maximum strength or 4mm ply cut into strips
waterbased glues give you maimum grip on the buiscuits as it makes them swell
- Has thanked: 77 times
- Been thanked: 335 times
Waterbased such as evostick, titebond etc is best.
The moisture content helps to expand the biscuits in the initial stages.
PU glues arn't as effective i have always been told. Although they have good bond strength.
- Has thanked: 16 times
- Been thanked: 9 times
