FUSED SWITCH WITH LIGHT ON CONSTANT PROBLEM
DIY MAN DIM
Post by DIY MAN DIM »
hi ,
i have wired a fused socket but the light is on all the time even when i press the switch off , any ideas :scratch:
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
:scratch:
a picture might help?
Why have you used a fused socket for a light?
or have you used an fcu?
DIY MAN DIM
sorry , i have'nt explained myself , its not a light on the wall or ceiling , its the led light on the socket , it tells you if the socket is on or off :oops:
Hoovie
Borders Bodger
Been thanked: 4 times
Post by Hoovie »
I would guess you have reversed the connections from the mains supply and the appliance connected to it it.
There is usually a set labelled Feed and a set labelled Load - the Feed is your incoming and the Load is the wires to your appliance. Check they are that way round
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Post by Rich-Ando »
Hoovie wrote:I would guess you have reversed the connections from the mains supply and the appliance connected to it it.
:thumbright: :thumbright:
DIY MAN DIM
THE WAY THEY ARE WIRED ,is this danaGEROUS AT THE MOMENT ?
Site Admin
It needs fixing as you do not know when the applicance connected to it is switched on or off and so it is potentially dangerous.
DIY MAN DIM
so what wires are the wrong way round ? :scratch:
DIY MAN DIM
its only for the washing machine
Site Admin
Is this a wind up?
Nobody is that stupid :roll:
If it is lit up all the time you do not know if it is switched on or off do you?
If you "think" it is switched off and try and repair the machine you may be electrocuted.
DIY MAN DIM
hi ,
honest this is no wind up , thats correct , the switch does work if you press it off , but the led is on whether the switch pressed or not , i know its souinds nothing major but i must have wired it wrong somehow ?
Site Admin
ok, the feed and load wires are the wrong way around.
They should be swapped so that they are the correct way around, so that the neon light goes off when the switch is in the off position :wink:
DIY MAN DIM
right thanks for your help , any ideas which ones ? :scratch:
Rich-Ando
Pro Tradesman
Post by Rich-Ando »
DIY MAN DIM wrote:right thanks for your help , any ideas which ones ? :scratch:
here's a BIG CLUE
ultimatehandyman wrote:ok, the feed and load wires are the wrong way around.
Rich-Ando
Pro Tradesman
Post by Rich-Ando »
i'm sorry i have just realised, i can solve your problem in one go: -
change the switch to one without a neon on then you won't know at all
..........hang on
TOP means towards the ceiling
Locked
Return to “Lighting”
