DIY - Tiling over Orby backboard using dowel fixings?
101_North
Post by 101_North »
Hi folks,
DIY'er here. I'm doing up our bathroom and have installed Orby boards as per the manufacturer instructions http://www.orbry.com/pdf/orbry-solid-wa ... -guide.pdf
My question is - the mechanical fixings protrude from the boards by about 2mm and my concern is that these will prevent me getting a good contact with the adhesive in places with a 6mm notched trowel that I was recommended for the job. My tiles are 400mm x 200mm and are 7mm thick. I'll be using bagged adhesive and want to get this right first time.
I was wondering if a 10mm notch would be more suitable and give me better adhesive coverage on the back of the tile?
Any advise would be fantastic.
101
Christian_Booth
Been thanked: 8 times
Re: DIY - Tiling over Orby backboard using dowel fixings?
Post by Christian_Booth »
If you have a 6mm notched trowel, and the screws stick out 2mm, I doubt by the time pressure is applied the tiles won't come into contact with the fixings. Just make sure the boards are very secure, no movement.
Sent from my SM-G935F using Tapatalk
101_North
Post by 101_North »
Thanks! I got an 8mm just in case I've any issues with the 6. Fingers crossed!!
101
