Hi gang,
Will be applying 300 x 600 wall tiles in the bathroom to Hardibacker or plaster board. Hardibacker in wet area and plasterboard in dry areas.
Would this mapei powder adhesive from Wickes be ok?
http://www.wickes.co.uk/Mapei-Mapeker-R ... g/p/102976
Thanks in advance [THUMBS UP SIGN]
Sent from my Moto G (4) using Tapatalk
Wall tile adhesive, Mapei ok?
- Has thanked: 25 times
- Been thanked: 4 times
- Has thanked: 104 times
- Been thanked: 490 times
Re: Wall tile adhesive, Mapei ok?
It's good adhesive but it's rapid drying and grey. But if you're not used to tiling or have light colour tiles then you'd be better off choosing a standard set white adhesive. I use this
Where can I buy that from? Didn't see it in Wickesdarrenba wrote:It's good adhesive but it's rapid drying and grey. But if you're not used to tiling or have light colour tiles then you'd be better off choosing a standard set white adhesive. I use this
I get it from my local independent tile shop
You can use this link to find your local stockist http://www.tilemasteradhesives.co.uk/stockists
- toolbox
- Has thanked: 128 times
- Been thanked: 210 times
Wickes do it in white too if you prefer. http://www.wickes.co.uk/Mapei-Mapeker-R ... g/p/112715
