plasterboard dot and dab or screw
hennase
Has thanked: 2 times
Post by hennase »
Good day folks. I am taking off some tiles in my bathroom as I have now found that our bathroom is 20mm higher at one end than the other. these tiles are 600mm long, I am now going to cut them on the short end (300mm) and put them right up to the ceiling. In my last post I said I had PVA'ed the wall, these are the tiles I am taking off. I wish to put plasterboard up and tile over it but not sure what fixing to use, dot and dab (but will it hold after this plonker put PVA on the wall) or screw and raw plug.
I'm sure you guys have the answer. Thank you in advance>
:huray: Kind regards Hennase
Notch1
Has thanked: 3 times
Been thanked: 91 times
Re: plasterboard dot and dab or screw
Post by Notch1 »
Would it better to use tile backer board?
