Sharp radius plasterboard
oz0707
Has thanked: 160 times
Been thanked: 67 times
Post by oz0707 »
Could I bend 9mm plasterboard to a sharp curve of around 4" 90 degrees?
I've got a solid former to bend against and fix in the form of a curved corner post. The pieces of board will be approx 12" high. This is for a bulkhead below a ceiling.
I thought I could try a combo of cutting back of board and damping to get the curve?
What is the solution for beading the bottom edge?
Notch1
Has thanked: 3 times
Been thanked: 91 times
Re: Sharp radius plasterboard
Post by Notch1 »
davyp1
Has thanked: 13 times
Been thanked: 181 times
Post by davyp1 »
:withstupid:
It's the obvious solution, Flexiboard is the way to go . . . .
davyp1
davyp1
Post by davyp1 »
I'm assuming the 'bottom edge' you refer to is a reflex angle!
In that case (or with an angle other than 90, you would use a
'thin skim stop bead'.
https://www.google.co.uk/search?hl=en&s ... mdfMdlaMKE
davyp1
Return to “Plastering Forum”
