What is the best adhesive to use on sand and cement screed
Like_knowlege
Has thanked: 6 times
Been thanked: 3 times
Post by Like_knowlege »
My builder is laying porcelain tiles onto new screed. (75mm). We will let it dry for 3 weeks and use ditra matting also.
What would you recommend as the best adhesive to use ?
We are laying a total of 50m2. The tiles are 8mm thick, and the width and length is 20cm and 120cm respectively.
I am thinking of a 3mm grout between the tiles .
Has thanked: 1414 times
Been thanked: 4015 times
Re: What is the best adhesive to use on sand and cement scre
I would query whether 3 weeks is enough.. Double that I'd have thought.
Mapie keraflex is my preference for porkies.
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
Surely your tiler would be using what they recommend?
It's not for the client to choose the adhesive
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
:withstupid:
And 3 weeks seems a bit soon unless it's been awfully warm in your neck of the woods.
Handyman in Sussex
Has thanked: 40 times
Been thanked: 51 times
Post by Handyman in Sussex »
:withstupid: With all of the above.
1mm per day drying time = 75 days.
Have you got UFH in the screed and if so has it been through it's warm up procedure yet? You can start that at 3 weeks.
Tile adhesive is for the tiler to choose not the client. (Or is the builder doing the tiling and asking you what to use......)
Like_knowlege
Thanks for all your suggestions. I found someone who said I can tile in 5 days. They use a additive and it is the real deal. So none of the 1mm per day waiting times
Ktuludays
Has thanked: 249 times
Been thanked: 212 times
Post by Ktuludays »
Handyman in Sussex wrote::withstupid: With all of the above.
And if it cracks does he cover any remedial work?
Sent from my HUAWEI VNS-L31 using Tapatalk
Like_knowlege
yes and insurance backed and been a month now and no problems
bc5843
Post by bc5843 »
Out of the 2 tilers I've used, they used either Dunlop or Norcros... not sure if they have a suitable tile adhesive for sand or cement screed, but might be worth looking at what they have available.
https://www.dunloptrade.com/tiling/tile-adhesive/
http://www.nxadh.co.uk/product-range/
Hope that helps!
kave
Has thanked: 7 times
Post by kave »
Old thread, but on the first page. The OP asked a simple question, so I thought I would respond with a simple answer for anyone searching in future.
For a sand and cement screed, any cement based adhesive is compatible and will give a perfect bond, after all they are both cement based. It's only liquid pourable screeds, calcium or other anhydride screeds which are fussy and require special attention paid towards adhesive selection.
