Have just had a rubber flat roof installed on a new extension and when looking out the first floor window can clearly read 1-2mm 70524 FR AG 1211 MADE IN USA is this how it should look or has the rubber membrane been laid upside down and if so does it matter or is it just cosmetic.
Many thanks in advance.
Charlie
Rubber Flat Roofs
- Has thanked: 2 times
- Has thanked: 6 times
- Been thanked: 187 times
Re: Rubber Flat Roofs
whats going on with posting replies, i posted reply here yesterdayan its disapeared?
the answer is theres no up or down side to the sheets.
- These users thanked the author wes56 for the post:
- charliecharlton
- moderator2
- UHM Super Moderator
- Has thanked: 154 times
- Been thanked: 566 times
SFAIA you are the only regular having this issue.wes56 wrote:whats going on with posting replies, i posted reply here yesterdayan its disapeared?
- Has thanked: 32 times
- Been thanked: 805 times
ive done a fair few rubber roofs. i used to lay it with the code words facing down so there was no unsightly writing to be seen.
last time i laid a rubber roof i discovered that the code words were on both sides. so either i got lucky or perhaps a different manufacturer. its a bit mad like but i guess just have to live with it.
- These users thanked the author fin for the post:
- charliecharlton
