Led lamps with dimmer
- Mooncat
- Has thanked: 81 times
- Been thanked: 72 times
Planning to install a 5 lamp chandelier with dimmable virtual filament lamps. But the dimmer switch I have is rated at 400watt max, 60watt upwards. The 5 lamps are nowhere near that greedy. Are dedicated LED dimmers available, or do I have to use one ordinary incandescent lamp in the mix?
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Led lamps with dimmer
I had 6 LED downlights installed in my boys room and the wife wanted a dimmer switch. My sparky mate did the work but he had to get a dimmer switch that was compatible with the LED downlights and it cost around 25 quid(ish) if I remember.
- These users thanked the author steviejoiner74 for the post:
- Mooncat
- Mooncat
Used my initiative,(should have done that first) and found this:
https://www.downlights.co.uk/led-dimmer-switch.html
less expensive than using incandescent!
- Mooncat
The cat is back! I hope I am still welcome.
I finally got my house, most of my stuff is there as well. I'll be installing the chandelier, or should I say electrolier as it has no candles, in February.
- Has thanked: 47 times
- Been thanked: 2590 times
Its not that bad.arco_iris wrote:DYOR, trailing edge & leading edge dimmers - it's something to do with AC current I can't get my head round.
A.C. Is alternating current
If you could see it, you would see a sine wave just like the one below
This sine wave is "moving" at 50 times every second.
A dimmer works by switching off the electricity.
A leading edge dimmer switches off just as the sine wave starts to "rise"
A trailing edge dimmer switches off just as the sine wave nearly "ends"
It takes a lot more electronics to make a trailing edge dimmer than it does a leading edge dimmer, so that is why most dimmers are leading edge, just because it costs less, and the fact when they were invented, trailing edge dimmers were not needed.
- Has thanked: 1415 times
- Been thanked: 4024 times
We all thought you had shuffled off this mortal...Mooncat wrote:The cat is back! I hope I am still welcome.
on the house move
- Mooncat
It is taking longer than I hoped, but I have some lives left, I hope. I am back in Wales until the end of February. I'll post some pix elsewhere.
