TIles have changed colour...
MollyImms
Has thanked: 2 times
Been thanked: 2 times
Leaking shower
Post by MollyImms »
Hello,
The sealant in my shower is split and clearly leaking because a couple of my tiles have gone dark, presumably because they're soaking up water. I can repair the sealant but I'm not sure what to do about the tiles. Will they dry out if I repair the sealant? Any advice would be much appreciated. Thanks.
wes56
Has thanked: 6 times
Been thanked: 187 times
Re: Leaking shower
Post by wes56 »
post a photos showing the area. you could be talking about anywhere in the shower an any kind of tiles
DIY_Johnny
Mr. Grumpy
Has thanked: 25 times
Been thanked: 109 times
Re: Leaking shower
Post by DIY_Johnny »
maybe its better to put this post in the tiling forums.
MollyImms
Post by MollyImms »
Hello,
The sealant in my shower cubicle has split vertically in the corner and is clearly leaking because a couple of my ceramic, white, wall tiles have gone dark, presumably because they're soaking up water. I can repair the sealant but I'm not sure what to do about the tiles. Will they dry out if I repair the sealant? Any advice would be much appreciated. Thanks.
OchAye
Has thanked: 855 times
Been thanked: 994 times
Re: TIles have changed colour...
Post by OchAye »
Post some photos please, something from a distance and some more close up.
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 566 times
Post by moderator2 »
Just one thread per topic please. I have merged these two.
Has thanked: 1414 times
Been thanked: 4015 times
Re: Leaking shower
MollyImms wrote:Hello,
No they won't dry out. They need removing first, then depending on how bad the water damage is behind you'll either need to hack off any damp plaster and allow the wall to dry out before re-plastering or remove / replace any damaged plaster board behind the tiling.
Re-tile once dry and remove and replace all the sealant.
MollyImms
MollyImms
Post by MollyImms »
Great thank you for the advice! Tiles will have to come off then.
