Brake disc's and pads
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
Re: Brake disc's and pads
My Honda CRV rear brake recently made sqeeking noise (I now know the pads have only acoustic wear indication) I searched alternative pads as the original always seemed too soft, bought Pagid from Euro Car Parts and though the web gave too many numbers the guy at the counter found another and they were spot on and feel better even though they are only on the rear, even my Son commented on the drive to drop me off at the airport, that they seemed to bite sharper; will replace the fronts with same soon; brembo also available and a cheaper own brand.If the car was in warranty then non OEM might be an issue.
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Can't see it making much of a difference either way. Both sets will (certainly should) be good enough to pass the MOT brake test but unless you're a driver that can 'feel' and/or use the difference in braking quality it has to be down to price/longevity.
- Has thanked: 250 times
- Been thanked: 212 times
I have fitted pagid on all my vehicles for years. Never had an issue with them.
Sent from my HUAWEI VNS-L31 using Tapatalk
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I think my van must have those, it's been squeaking a bit for the last few days when I use the brakes. I'll take a look in my handbook later and see what it says.aeromech3 wrote: (I now know the pads have only acoustic wear indication)
- Has thanked: 3 times
- Been thanked: 18 times
Pagid supply pads/discs to Toyota (and others) They'll be exactly the same.
Yep, and Textar and Pagid are owned by the same company.curtains wrote:The picture on ebay is showing Toyota Textar on the pads.columbiers wrote:Pagid supply pads/discs to Toyota (and others) They'll be exactly the same.
As I said above they'll be exactly the same.
- Has thanked: 105 times
- Been thanked: 878 times
I like Mintex pads and discs the pads are just the right type of compound not so hard they eat the discs or to soft they dust up badly
price up the oem pads and discs they maybe cheaper than you think
