2004 Focus - Weird noise!
jeigen3489
Post by jeigen3489 »
I own a 2004 1.6 Ford Focus Zetec.
Recently I have noticed a noise I’d not heard before. It seems like it’s coming from the back of the car and from inside the car, while driving, the noise sounds like when a motorbike is driving near you or a distant propellor plane. It starts getting quite prominent at around 25mph and gets louder the faster you go. I have noticed it has more to do with speed than engine revs, as when I take my foot off the gas I can still hear it and it gets quieter as the car slows down.
The only thing changed recently in the car is a newly installed rear tyre.
Any ideas?
Thanks!
Has thanked: 823 times
Been thanked: 3560 times
Re: 2004 Focus - Weird noise!
Probably a wheel bearing it makes an annoying noise at certain speeds. Not terminal if you can find a cheap mechanic to do it see https://www.youtube.com/watch?v=K1kCS2b8oR4
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Hole in the exhaust is my suggestion.
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
As DWD says, could be a wheel bearing. Might be a noisy tyre as well. Some are noisier than others. Try putting the spare on if you have one. See if it the noise goes.
Rorschach
Has thanked: 109 times
Been thanked: 1038 times
Post by Rorschach »
If the noise is unrelated to engine revs then it must be something in the drive train. Wheel bearings can make some odd noises, could be a worn bushing, could be that the new tyre you got is not balanced properly.
Jack up the rear of the car and spin the tyres manually, you can normally feel/hear dodgy bearings doing this.
Has thanked: 1415 times
Been thanked: 4024 times
First thing to check would be tightness of wheel nuts.
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
The sound changes with speed = classic wheel bearing (a humming sound) - A garage will be able to tell in minutes of putting it in the air, if the bearings haven't been changed before there way over due - if the bearings are good look at the tires age, type, wear and/or get them balanced
If your are getting the job done get them to fit decent bearings not cheap crap otherwise a year - 18 months you will be doing them/it again, never had a issue with a SKF bearing
Ktuludays
Has thanked: 250 times
Been thanked: 212 times
Post by Ktuludays »
I'd go with tyre. My Mazda 3 has drone like sounds from the rear. All bearings are good and even different tyres have the same noise just different volume levels. Only notice it above 30 mph
Sent from my HUAWEI VNS-L31 using Tapatalk
