Wall tiles for front porch
97browng
Has thanked: 2 times
Been thanked: 5 times
Post by 97browng »
Hi All,
We live in a Victorian house and are looking to get some wall tiles for the porch at the front of our house. Its only a small area outside just before entering the front door and many other people in the area seem to have the original tiles (unfortunately the previous owners of our house have removed them).
We found some nice tiles and went to buy them but on informing the staff they were for outside we were told that they were not suitable. They said that even though the porch is covered the problem is temperature and if it gets below 0C they will crack. We asked him which tiles were suitable and he said there were only a small selection in the shop but these were mostly floor tiles
Looking online we are finding it very difficult to find suitable tiles. Most of them are indeed floor tiles and wont work for the porch wall. Is anyone able to suggest what tiles we should use and where we can get them from please? I have read that porcelain should be fine, but when looking online a load that have porcelain in the title say they are actually ceramic and not suitable for outdoors.
Any help appreciated.
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: Wall tiles for front porch
Post by ayjay »
These are porcelain floor tiles, they've been down in my (open, North facing) porch for many years without any problems.
IMG_4524 modified.jpg (389.36 KiB) Viewed 3621 times
I also make ceramics as a hobby. Stoneware or Porcelain pots if fired to maturity will survive out doors so long as they don't actually fill with water which is allowed to freeze.
Earthenware, (think terracotta flower pots) is fired to a lower temperature, remains porous, and can take up water which will freeze and crack the pots.
Has thanked: 735 times
Been thanked: 2339 times
there is a possibility just a possibility they may have just covered over the old tiles :dunno:
Manc chippy
Has thanked: 8 times
Been thanked: 14 times
Post by Manc chippy »
I have never seen a problem. You need to use a good flexible adhesive and grout
97browng
Post by 97browng »
Thanks for the replies all.
Yes we had hoped they had covered over the old ones, but on looking found they had removed them :(
So we were going to go for a selection of these http://www.tilegiant.co.uk/deep-metro-g ... 0x200.html with some trim and border etc... Do you think they will be ok to use on the wall or should I specifically go for porcelain ones?
As for adhesive I was going to get the Norcros Rapid Set Tile Adhesive (https://www.travisperkins.co.uk/Norcros ... g/p/735716#) and them some grout. Does this sound ok or do you have any suggestions?
Gary
Manc chippy
97browng wrote:Thanks for the replies all.
Gary
Go for the nx universal flexible tile adhesive
vnutter
Post by vnutter »
any tiles going outside should be frost proof i.e. a porcelain type regardless. open and porous wall tiles should never be fixed externally
