Is this ok?
Gadget
Jack Of All Trades
Has thanked: 347 times
Been thanked: 343 times
Is this ok?
Post by Gadget »
Any comments, and is this ok to do?
http://www.metacafe.com/watch/307660/in ... rformance/
By eck! ©
RichieP
UHM Super Moderator
Has thanked: 4 times
Been thanked: 12 times
Post by RichieP »
It's OK but the long way round.
Slightly quicker to go Start > Run, type msconfig and press Enter.
Click the Startup tab and you'll see the same list.
To see what the programs are, drag the small vertical line between Command and Location until you can see the .exe.
Remove the tick from any that don't need to run at startup.
If you're not sure, enter the .exe name into Google to find out.
If you're still not sure, download and run Windows Startup Inspector.
Make sure you're connected to the internet and click Consult.
It checks its online database and will tell you what can be safely removed and do it within the program.
Gadget
Jack Of All Trades
Post by Gadget »
Cheers Richie, I'll do it using one of your suggested methods!
By eck! ©
Return to “Computers”
