fixing into steel ?
fixing into steel ?
Top tip for drilling into steel. Start with a small 1 or 2mm drill bit (which will go though fairly easy) then drill out the same hole going up 1/2mm drill bit each time. You'll breeze though the lot in no time
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 566 times
