2004 Nissan Primera stalling after high revs
- Has thanked: 1 time
Hi, I am hoping someone can shed some light on the problem I am having...
My 2.0 petrol Primera is stalling after high revs, usually when stopping at junctions etc.
Today when parked up I reved the engine up and when the revs came back down it cut out, however if I only rev up to 2500 rpm it returns to idling no problem.
Any help would be much appreciated.
Re: 2004 Nissan Primera stalling after high revs
Just a quick update, it only does this when the engine is at temperature, it is fine when it’s cold
- Has thanked: 105 times
- Been thanked: 879 times
what Year ? is it the SR20 (P11) ? or later QR20 (P12)
ICV (idle control valve) or throttle body - I would carefully clean the throttle body with carb cleaner,
Not 100% sure but depending on year it may use a MAF (mass airflow meter) I would check it with a scan tool to see what its reading
- These users thanked the author Bob225 for the post:
- Fletcherl9
2004 p12, I will try cleaning the throttle body... fingers crossedBob225 wrote:what Year ? is it the SR20 (P11) ? or later QR20 (P12)
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Stop 'revving it' - what purpose does doing it achieve? Just turn the engine off.
It's akin to 'my head hurts' - 'so stop banging it against a wall then!'
04 it will have a TB and MAF, it may have a code logged in the ecu but not may not put the money light on
It happens intermittently when I stop at junctions or lights, I had a suspicion that it only happened if I was at higher rpm before I stopped, I reved it when I was parked to confirm that this was the case. In future it might be worth only posting on a topic if you have something of use or constructive to say.kellys_eye wrote:Stop 'revving it' - what purpose does doing it achieve? Just turn the engine off.
Cleaned the throttle body and it’s working perfectly, thank you for the help. This 30 minute job saved me an expensive trip to the garage.Bob225 wrote:what Year ? is it the SR20 (P11) ? or later QR20 (P12)
Thanks again
