DIY car service ramp
- Has thanked: 145 times
- Been thanked: 129 times
Hi
I want to build a car service ramp made of wood, for general service and repair. I have seen few on you tube and will look similar to the pic attached. My car's curb weight 1500- 1930 Kgs
My question is whether Treated softwood Joists is good for the job? Pic attached.
Many thanks
Many thanks
- joist.png (222.77 KiB) Viewed 4261 times
- Car Ramps 011.jpg (48.08 KiB) Viewed 4261 times
- Has thanked: 109 times
- Been thanked: 1038 times
Re: DIY car service ramp
Should be fine for occasional use. However a pair of steel ramps is not a lot of money and would last a very long time.
Steel ramps are fine and cheaper from my proposed wood ramp but they are less than 250mm width, my fronts are 245mm and rears 275mm so not suitable really.Rorschach wrote:Should be fine for occasional use. However a pair of steel ramps is not a lot of money and would last a very long time.
It is for occasional use, oil change....etc.
Cheers
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
Staggered that size - something pretty hot then. Make sure that you construct the ramp at a shallow angle if you don't have much ground clearance. I can't use steel ramps, my car won't go up them due to the overhang.yartin wrote:my fronts are 245mm and rears 275mm
My steel ramps are fairly narrow, narrower than the tyres I think but I don't have any trouble.
Fair enough if you want to make your own though, you might want to add lipping either side to help stop them sliding out as you drive up them. And as arco says since you are making your own, make them longer and shallower. That is my only complaint about mine, they are steep and can be hard to drive up slowly, even worse for reversing onto.
- Has thanked: 105 times
- Been thanked: 878 times
sounds like a BMW, If I had space for a garage I would have a scissor lift or even a quickjack if space was tight (neither are cheap)
Yes it an E63. I just use the driveway for basic services and repairs.Bob225 wrote:sounds like a BMW, If I had space for a garage I would have a scissor lift or even a quickjack if space was tight (neither are cheap)
- Has thanked: 1300 times
- Been thanked: 1175 times
Does it come with the car?jaeger wrote:I was looking at a car lift in Costco this week, not much change from a grand
Not cheap, but if you do a lot of work on cars, even small scale professionally then a lift like that would make life a lot easier and the added bonus is you can move it around unlike a proper garage lift.
- arco_iris
Ah, one o' them thar new-fangled tanks, a "Bangle-butt GT"!yartin wrote:Yes it an E63
E31 here, yartin - from when Grand Tourers really were.
E31 very nice car, mine is 650arco_iris wrote:Ah, one o' them thar new-fangled tanks, a "Bangle-butt GT"!yartin wrote:Yes it an E63
That's a Quickjackjaeger wrote:I was looking at a car lift in Costco this week, not much change from a grand
650 that's the 4.8 V8 isn't it, I always like the look of the 635 (E24 ?) they where dirt cheap in my teens now a good one goes for silly money
