DIY car service ramp
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
Hi
I want to build a car service ramp made of wood, for general service and repair. I have seen few on you tube and will look similar to the pic attached. My car's curb weight 1500- 1930 Kgs
My question is whether Treated softwood Joists is good for the job? Pic attached.
Many thanks
Car Ramps 011.jpg (48.08 KiB) Viewed 4267 times
Rorschach
Has thanked: 109 times
Been thanked: 1038 times
Re: DIY car service ramp
Post by Rorschach »
Should be fine for occasional use. However a pair of steel ramps is not a lot of money and would last a very long time.
yartin
Post by yartin »
Rorschach wrote:Should be fine for occasional use. However a pair of steel ramps is not a lot of money and would last a very long time.
Steel ramps are fine and cheaper from my proposed wood ramp but they are less than 250mm width, my fronts are 245mm and rears 275mm so not suitable really.
It is for occasional use, oil change....etc.
Cheers
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
yartin wrote:my fronts are 245mm and rears 275mm
Staggered that size - something pretty hot then. Make sure that you construct the ramp at a shallow angle if you don't have much ground clearance. I can't use steel ramps, my car won't go up them due to the overhang.
Rorschach
Post by Rorschach »
My steel ramps are fairly narrow, narrower than the tyres I think but I don't have any trouble.
Fair enough if you want to make your own though, you might want to add lipping either side to help stop them sliding out as you drive up them. And as arco says since you are making your own, make them longer and shallower. That is my only complaint about mine, they are steep and can be hard to drive up slowly, even worse for reversing onto.
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
sounds like a BMW, If I had space for a garage I would have a scissor lift or even a quickjack if space was tight (neither are cheap)
yartin
Post by yartin »
Yes I am making a bit longer than the ones you buy of the shelf so can get a shallow angle. Plus a lipping to help stop when it is up to the last plank.
yartin
Post by yartin »
Bob225 wrote:sounds like a BMW, If I had space for a garage I would have a scissor lift or even a quickjack if space was tight (neither are cheap)
Yes it an E63. I just use the driveway for basic services and repairs.
jaeger
Has thanked: 40 times
Been thanked: 76 times
Post by jaeger »
I was looking at a car lift in Costco this week, not much change from a grand
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
jaeger wrote:I was looking at a car lift in Costco this week, not much change from a grand
Does it come with the car? :lol:
Rorschach
Post by Rorschach »
Not cheap, but if you do a lot of work on cars, even small scale professionally then a lift like that would make life a lot easier and the added bonus is you can move it around unlike a proper garage lift.
arco_iris
Post by arco_iris »
yartin wrote:Yes it an E63
Ah, one o' them thar new-fangled tanks, a "Bangle-butt GT"!
E31 here, yartin - from when Grand Tourers really were.
yartin
Post by yartin »
E31 very nice car, mine is 650
Bob225
Post by Bob225 »
That's a Quickjack
650 that's the 4.8 V8 isn't it, I always like the look of the 635 (E24 ?) they where dirt cheap in my teens now a good one goes for silly money
