Dot n dab celler walls
Ouch-that-hurt
Has thanked: 14 times
Been thanked: 3 times
Post by Ouch-that-hurt »
Hi..... celler walls have had a slurry brushed on them (KA slurry) and seem to be dry. should I be ok using the dot n dab method or stud the walls out? and what type of plasterboards would you recommend? cheers :dunno:
