ELECTRICAL BOX SINKER
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
I'll have about 10 double sockets to sink into Block and I'm getting lazier, was looking at these Box Sinkers link http://cgi.ebay.co.uk/Square-Hole-Box-C ... dZViewItem
I know I'll need the circular cutter too.
Has anyone got experience of them?
Are they good?
Any suggestions where to buy, other than eBay.
I've seen the Armeg Sets are they are a lot more expensive, I'll not be cutting holes every day.
Jaeger.
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
I have the Armeg set and it is not brilliant to be honest.
Firstly you need a drill with rotor stop on for the chisseling part.
The cutter makes an enourmous amount of dust and the square cutter attachment will not work in hard brick and so you have to use a chisel in any case.
When trying to use the square cutter the amount of vibration caused is significant and so if you are working on an old house you could push the brick/s right through the wall, cracking the plaster at the other side ( on single brick internal walls)
My advice would be to get a good quality 8mm/10mm drill bit and use depth stop on your sds drill and pepper pot where the boxes need sinking and then get a good quality chisel for your sds drill ( as long as it has rotor stop) and then remove the centre with this.
The box sinkers are supposed to be ok for some materials, but for me it is much easier with a sds drill bit and chisel.
here is a rough guied on how to do it-
http://www.ultimatehandyman.co.uk/SINKI ... CK_BOX.htm
sparkydude
Has thanked: 2 times
Been thanked: 149 times
Post by sparkydude »
I agree with handyman on this one, i have the set and it does create a lot of vibration, but in your case on block it will be a dream to use and will save you loads of time and effort, wil go niceley with your ryobi drill.
Nick
Return to “Tool Talk”
