How strong is steel reinforced epoxy (cold or chemical weld)?
Lance_dBoyle
Post by Lance_dBoyle »
I need to weld a nut to a stainless steel tube but I do not have a welder. I do have something called J-B Weld steel reinforced epoxy which I believe is also known as cold welding or chemical welding. I plan to have a threaded rod go through the tube and screw into the nut, and the rod, tube and nut will be subject to a lot of vibration. I wonder about the strength and durability of using epoxy. The product says it can withstand 5020 psi. Does anyone have experience with chemical welding? How does the bond compare to conventional welding? Do you have any recommendations or another way to securely afix a nut to a tube? Thanks
Has thanked: 823 times
Been thanked: 3560 times
I used it to repair a cast aluminum Pressure Relief Valve on my vintage tractor. It was a pinhole that developed and oil squirted out. The repair was fine
I do not know how it will work for you but it must be really clean to get a good bond. I used carburetor cleaner spray.
I think it is worth a try for six quid.
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
Get it tig welded or use a rivnut imho
Rorschach
Has thanked: 109 times
Been thanked: 1038 times
Post by Rorschach »
Use the glue and then drill and cross pin it.
jaeger
Has thanked: 40 times
Been thanked: 76 times
Post by jaeger »
Without a welder I'd also use a rivnut, for a one-off you don't even need the tool, it can be done without.
https://www.youtube.com/watch?v=I6H6wr7fJYo
Argyll
Has thanked: 1183 times
Been thanked: 581 times
Post by Argyll »
You learn something every day. I didn't know what a rivnut was.
jaeger
Post by jaeger »
Rivnuts are very useful, you can also get them in stainless steel ( a bit harder to install) if OP wants to keep all the materials the same.
UHM Also has his own video (I forgot about this)
https://www.youtube.com/watch?v=f7yIqKnLGPc
Bob225
Post by Bob225 »
If rivnuts are new, Cleco's will blow your mind http://clecofasteners.info/
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
FLow drilling and tapping is a handy process for manufcturing...
https://www.youtube.com/watch?v=7YSVClLMp60
jaeger
Post by jaeger »
Bob225 wrote: Fri Jan 31, 2020 4:50 pm If rivnuts are new, Cleco's will blow your mind http://clecofasteners.info/
I first saw Cleco being used on 'A plane is born' I used to enjoy that series of 'A XXX is born'
Bob225
Post by Bob225 »
jaeger wrote: Fri Feb 07, 2020 6:51 pm I used to enjoy that series of 'A XXX is born'
Wasn't that a Louis Theroux documentary :lol:
The cleco clamps are very good too
jaeger
Post by jaeger »
Last year at a car boot, I saw a box full of them but no insert tool, should have bought them but I just passed them by :cb
