Push fit elbow for electric shower?
plumbing, drainage and waste water questions here please
tadaska
Has thanked: 227 times
Been thanked: 11 times
Post by tadaska »
The instructions say to use a push fit elbow that does not require special tools for removal. I've never even seen a push fit elbow. Can you guys recommend one?
Also how do I dress up that ugly looking overflow pipe? Are there some sort of fitting I could buy to put on that pipe?
Rorschach
Has thanked: 108 times
Been thanked: 1038 times
Post by Rorschach »
JG speedfit comes in all shapes including elbows.
tadaska (Fri Feb 21, 2020 4:12 pm)
tadaska
Post by tadaska »
Rorschach wrote: Fri Feb 21, 2020 2:59 pm JG speedfit comes in all shapes including elbows.
So I just buy a JG Speedfit elbow, clean up that pipe and Bob's my uncle? Do they slide in and out once fitted if I need a bit of adjustment when fitting the shower on the wall?
ahfix
Has thanked: 61 times
Been thanked: 184 times
Post by ahfix »
tadaska wrote: Fri Feb 21, 2020 4:15 pm
No they don't slide, just rotate. Link elbow
[/youtubeshort]
These users thanked the author ahfix for the post:
tadaska (Sat Feb 22, 2020 3:05 pm)
tadaska
Post by tadaska »
Done. Almost. Cables need connecting. I'll do it in the morning when I have more daylight. No leaks so far.
When it is all connected should I seal the holes with silicone or leave them as they are?
Rorschach
Post by Rorschach »
They shower shouldn't be spraying water over there so you shouldn't need to seal the holes. What I generally do once the cover is fitted though is run a bead of silicone over the top and a down the sides, this stops water running behind but will let it drain out of the bottom if a pipe leaks etc.
tadaska (Sun Mar 01, 2020 8:45 am)
Return to “Plumbing Forum”
