The instructions say to use a push fit elbow that does not require special tools for removal. I've never even seen a push fit elbow. Can you guys recommend one?
Also how do I dress up that ugly looking overflow pipe? Are there some sort of fitting I could buy to put on that pipe?
Push fit elbow for electric shower?
- Has thanked: 108 times
- Been thanked: 1038 times
JG speedfit comes in all shapes including elbows.
- Has thanked: 227 times
- Been thanked: 11 times
So I just buy a JG Speedfit elbow, clean up that pipe and Bob's my uncle? Do they slide in and out once fitted if I need a bit of adjustment when fitting the shower on the wall?
- Has thanked: 61 times
- Been thanked: 184 times
Done. Almost. Cables need connecting. I'll do it in the morning when I have more daylight. No leaks so far.
When it is all connected should I seal the holes with silicone or leave them as they are?
They shower shouldn't be spraying water over there so you shouldn't need to seal the holes. What I generally do once the cover is fitted though is run a bead of silicone over the top and a down the sides, this stops water running behind but will let it drain out of the bottom if a pipe leaks etc.
