Video of how to resize/add a pic to your post
- Has thanked: 47 times
- Been thanked: 2596 times
Most forums have a limit as to how big a picture can be that you can add to your post. (We like pictures, it makes things easier to understand)
To add a picture is easy (See my signature) but often you can not use your picture because it is too big (To the computer, it is too big)
I use an easy to use website and that is totally free. The website is Picresize.com
It is also easier to watch someone-else do it, so now you really can watch someone-else (me) do it.
. Disclaimer:
This should work what ever you have be that a pc or an ipad. Sorry, I do not have an ipad to test it with.
There are other resizing programmes out there, but this is totally free, and you do not need to download anything (other than your picture)
It may seem hard to use, but like anything, the more you use it, the easier it becomes.
If you think you can make a better video, then please do.
If you want to watch a bigger version (UHM software makes it smaller) click Here
. Disclaimer:
- These users thanked the author Someone-Else for the post (total 2):
- London mike 61 (Thu Apr 02, 2020 9:58 am) • ultimatehandyman (Mon Apr 06, 2020 11:06 am)
- Rating: 14.29%
- Has thanked: 826 times
- Been thanked: 3588 times
- jaeger
- Has thanked: 40 times
- Been thanked: 76 times
I use microsoft image resizer, just right click on picture and select resize free to use, I use it on win 7 but it says can be used on win 10
https://www.microsoft.com/en-us/p/resiz ... verviewtab
( I just took pic with phone for these, just to show )
- 2020-04-02 09.33.57 (Small).jpg (78.98 KiB) Viewed 6277 times
- 2020-04-02 09.34.18 (Small).jpg (91.86 KiB) Viewed 6277 times
- Has thanked: 285 times
- Been thanked: 403 times
Well done SE, I will have a go later and try to post a picture of something as a test.
Mike
Mike
- These users thanked the author London mike 61 for the post:
- Someone-Else (Thu Apr 02, 2020 10:19 am)
It worked
Mike
- Argyll
- Has thanked: 1188 times
- Been thanked: 583 times
Kind of
- These users thanked the author Argyll for the post:
- London mike 61 (Thu Apr 02, 2020 3:28 pm)
Cheeky bugger!
Mike
- Argyll (Thu Apr 02, 2020 4:20 pm)
- Has thanked: 10 times
- Been thanked: 194 times
With my I Pad all you do is click on add files, choose a photo, at the bottom of the window gives you size options I use medium , click done and then place in queue , job done . hmm unless you have I pad upside down and photo comes out upside down, make sure button is on right, I forget being a left handed person sometimes
- Argyll
I use MS Office picture manager. They stopped supplying it as standard but if you download MS sharepoint it's on there.
I simply don't trust companies with my photos. I was once told if anythings free then you are the product.
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
As I'm on Linux Mint, I use Gwenview for pictures that need edit; there is also another tab "open menu" which gives the print, copy etc.
- Gwenview.png (105.99 KiB) Viewed 948 times
