Are these switches still available?
- Has thanked: 110 times
- Been thanked: 1039 times
It's a 2 way switch used on a landing, as you can see there isn't room for a standard switch.
- IMG_20200406_150738.jpg (30.98 KiB) Viewed 1721 times
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I think they're known as Architrave switches (if that helps a search).
Ah yes that does help. I had no idea what to search for, amazing how easy it is when you have the right search term!
- camallison
- Has thanked: 127 times
- Been thanked: 108 times
I saw some in the Screwfix catalogue I think. Worth a look.
Colin
Colin
- Has thanked: 823 times
- Been thanked: 3562 times
Oh yes, I had to look, but I am sure R has found them already https://www.screwfix.com/p/crabtree-ins ... hite/271hv
Ooof screwfix are pricey!
We are hoping that the old one will come up ok when cleaned, need to get the awful labels off etc. Before potentially making the problem worse though I wanted to check I could buy a replacement if needed.
Ebay came up as best price with postage etc. £4 delivered. They are only £2 on an electrical retailer site but the postage is high unless you spend a minimum amount. £4 is absolutely fine though, assuming we need it.
- Has thanked: 10 times
- Been thanked: 194 times
I normally take the switch or socket off, then clean using Jiff and a greenee
Then set aside in a warm place to throughly dry and refit
That was going to be my first attempt, I use it for a lot of cleaning.
