musty smell in gas elec understairs cuboard' concrete floor
hooly
Has thanked: 1 time
Been thanked: 2 times
Post by hooly »
there is a very dry concrete floor were gas elec boxes are' its been like it since moving in 5 yrs' i never took much notice till now' ive emptied the cupboard cleaned out' bit of bleach and left some baking soda in a bowl
would pva seal the floor? or any ideas' its more a musty smell
cheers
Surveyorman
Post by Surveyorman »
The musty smell your are referring to is more than likely associated moisture laden air being trapped in this area. Before you consider "sealing" the floor with anything let's establish a few things if possible - How old is the house we are talking about here? Are all the floors concrete like this or is this an infill in the under stair cupboard area only?
hooly
Has thanked: 1 time
Post by hooly »
prob 50 yrs if not bit more' all concrete floors yes' that is slightly raised to the hallway floor
hooly
Has thanked: 1 time
Post by hooly »
i used to think it was just a dusty floor' then had a cardboad box of books in there' thats when noticed more' its a cold floor'
Has thanked: 47 times
Been thanked: 2603 times
What ventilation is there?
hooly
Has thanked: 1 time
Post by hooly »
none' it very rarely opens' sometimes weeks on end
Surveyorman
As Someone-Else might be driving towards, I would look to creating some ventilation to the under stair cupboard area. The musty smell that you are noticing is more than likely trapped moisture laden air that causes condensation to form in this area. The fact that you have noticed that the floor is a “cold spot” would mean that moisture laden air will be attracted to this space as moisture particles move from areas of high pressure to low pressure. When the moisture laden air gets to the cold floor it cannot hold its moisture particles any longer as the temperature of the air begins to drop below what is known as the Dew Point. This is the temperature at which condensation is formed. I have seen good results from air bricks being installed if your cupboard is on an external wall. If not, consider creating a vent in the cupboard door. It sounds as though this area may also benefit from an increase in heating. I wouldn’t use any sealant on the floor as this will probably just make the floor appear wet when condensation occurs. Think about ventilation and heating.
hooly
Has thanked: 1 time
Post by hooly »
ok cheers' ive never seen any damp condensation' ive stored things all been ok' bar noticed a smell on the cardboard box' i will look towards getting a new door with the slats in or similer' a rad is opp but wont be on for a while now' it does seem as the smell is on the concrete' so maybe leave open for a few days' then get a new door' when things get back to norm cheers
it is a outside wall' air brick in the cuboard next to it' which is ok
but may be cheaper for the door'
cheers
hooly
Has thanked: 1 time
Post by hooly »
just thinking there is a passageway with next doors house attached as the roof of the passage way, there is water tap n water meter, also a few cracks about 5 10 mill and the damp course is about 2 bricks to a brick and half over, sometimes the concrete outside seems damp, ive yorkshire water coming to check for any leaks,
