Light switch help please - I’m lost!
Morning all. I have changed 3 switches around the house, from plastic to metal faces. Thought I had this nailed but then was presented with this configuration and I’m lost. Any help would be awesome, thank you.
- C568DC45-15C3-4058-87B6-80AC3E829910.jpeg (256.49 KiB) Viewed 1225 times
- 413350F9-7C14-4839-87A0-75F39A95ED97.jpeg (187.89 KiB) Viewed 1225 times
- 7C9757CD-D80A-4B2B-AE64-F16BE9CC207A.jpeg (203.29 KiB) Viewed 1225 times
- Has thanked: 47 times
- Been thanked: 2590 times
They are both the same switches (Two switches sitting side by side)
The new one, both switches are the same way round.
The old one each switch is upside down to the other.
Also if you look at your old switch, on the back of the plate (Not on the actual switch) it has the same names your new switch does.
I would also suggest you mark each wire (tape or pen) then take another picture, just incase you get disturbed while changing them over.
Thank you very much both. I will do it this morning and let you know if I’m successful.
